Spax Shock - Knackered Adjuster
suspension
12 replies to this topic
#1 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 27 April 2021 - 10:27 AM
A question for all you suspension gurus - I'm finally getting rid of the weird front springs/rear cones mix on my Jap import 93 SPi, and in doing so I tried to free up the adjuster on one of the front Spax High Performance gas shocks, which was seized. It's now free but too much so as it rotates without any stop point. Does anyone know if a repair is cost effective, or am I better off just getting new shocks (front only or all round)?
#2 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 10:28 AM
New shocks all round and replace the front cones.
Use KYB Gas ajust shocks
#3 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 27 April 2021 - 01:18 PM
Thanks - I should have said I'm going for new red spot cones all round. Will price up the KYBs now...
#4 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 01:27 PM
Here's a link to them, I should have put it in the above post, my apologies!
Minispares.com PN MSSK3015
https://www.minispar...px|Back to shop
#5 Midas Mk1
Midas Mk1
  • 5,797 posts
  • Local Club: S.U.N.M.C
Posted 27 April 2021 - 02:56 PM
You’ll be disappointed going from spax to kyb
#6 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 03:24 PM
I've had spax before and they're way too hard for a mini
#7 Midas Mk1
Midas Mk1
  • 5,797 posts
Posted 27 April 2021 - 05:11 PM
I run protec & spax, drove a good few miles in a friends with kyb and their way way too soft.
#8 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 05:23 PM
Having been In a mini with Gaz shocks(13 inch Sportspack wheels) and my own Clubman Estate (10 inch Cooper Steel wheels) with Spax krypton adjustable shockers, I feel both are too hard for a road mini.
Purely my opinion but I definitely put the spax adjustables back on the shelf
Edited by cal844, 27 April 2021 - 05:25 PM.
#9 petey81
petey81
  • 1,346 posts
Posted 27 April 2021 - 05:32 PM
I've had spax and gaz. Kyb gas adjust are great shocks so are kyb products
#10 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 07:21 PM
I agree, if I was needing adjustable shockers I'd fit Protech BUT Zas a budget friendly Choice, KYB hands down
Edited by cal844, 27 April 2021 - 07:22 PM.
#11 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 27 April 2021 - 08:33 PM
Thanks for all the opinions guys - the thing I love about Minis is the different ways to skin the same cat. Mine has 10" wheels and I'm after real-world handling on ropey B-roads, not track precision.
To open another can of worms, should I be putting on a camber kit while everything's in bits?
#12 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 27 April 2021 - 08:43 PM
Personally I'd go for a full alignment CHECK before you do strip the car, so you know what it's set at,
It's pointless getting the suspension alignment set until you've rebuilt the suspension. (due to wide tolerance build up)
So for a full list, assuming there's play evident when checked.
I'd fit new cones all round (unless the rears are good)
Front arm rebuild kits
Radius arm rebuild kits
Knuckle joints and seats all round
Track rod ends
New rubber bushes.
All the above list can be reduced as you need, depending on the condition of the parts on the car.
Personally I wouldn't fit a camber kit unless I couldn't get within tolerances.
On shockers I'd fit the KYBs on a road car, my estate is more fun to drive with the KYB shocks and new Red Spot cones than it was on the Spax.
I hope this helps
Edited by cal844, 27 April 2021 - 08:44 PM.
#13 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 27 April 2021 - 08:47 PM
Excellent tips, thanks
Also tagged with one or more of these keywords: suspension
