I had exactly that on a 1275 'S' and it ws DGS (Dirt, grit & s***) in th pressure relief valve. That was despite a thorough clean of everything before final assembly.
That needs to be the first thing to check.
Posted 06 May 2021 - 09:40 AM
Posted 06 May 2021 - 09:41 AM
I had exactly that on a 1275 'S' and it ws DGS (Dirt, grit & s***) under the pressure relief valve seat. That was despite a thorough clean of everything before final assembly.
Posted 06 May 2021 - 09:49 AM
If Changing the oil filter, I use Mann or Framm filters, I'd then check for flow to the head
Cal844
It’s a brand new MG Rover one that I fitted on rebuild
Posted 06 May 2021 - 09:51 AM
yeah I think this will be the first check this evening - I really don’t want to pull the engine unless i really have no other option
Posted 06 May 2021 - 10:20 AM
If you initially had pressure it is unlikely to be a build issue. The rubber ring is not easy to distort and even withour the ring, it is unlikely the pressure would go to zero.
The symptons are exactly what you would expect with a stuck relief valve. When mine happened it was on the first rally after building the engine. At normal tickover when hot it was reading virtually zero, but when revved over 4000 rpm it climbed to 50+ psi and at 6000 rpm it was 75 psi. On removing the plunger, which was hard to get out as it was partly jammed by a small piece of swarf, it was obvious that it had stuck in the open position. Cleaned up the bore and seat for the plunger, polished the plunger with 1500 wet & dry, then with 'Brasso' and it was fine. I also put a small washer under the spring to slightly increase the spring load.
I'm fairly sure that is your problem. I guess you were only using quite low revs at the time.
Good luck with it.
Posted 06 May 2021 - 10:44 AM
Good luck with it.
Thanks cooperman
yeah It was only running to first set the ignition timing - it dropped to about 20psi during this .... then out the gate up the road so was running at low revs for 10 mins then upto about 3000 rpm to check gear changes that’s when I noticed it had dropped to 0
Posted 06 May 2021 - 11:13 AM
Alternatively it could simply be the gauge. Do you have a low-pressure warning light as well as a gauge. Either fit a low-press warning light, or check the gauge on another vehicle. That's after removing the plunger and checking for DGS in the bore/seat.
Posted 06 May 2021 - 11:56 AM
I had the low pressure light wired while testing the engine out of the vehicle .. but since fitting the engine I didn’t wire it up because I had other wiring that needed doing to start from key and thought I could rely on the gauge.. it’s only a couple of wires so will wire it up
Posted 06 May 2021 - 07:19 PM
Edited by 84sprite, 06 May 2021 - 10:42 PM.
Posted 06 May 2021 - 07:40 PM
Posted 06 May 2021 - 07:44 PM
Air in the pipe preventing it reading. Was there oil flow to the rocker assembly?
Air in the pipe makes no difference to the pressure read. A blockage would.
Posted 06 May 2021 - 07:57 PM
Posted 06 May 2021 - 11:00 PM
Well done, problem sorted with no need to do anything serious.
Posted 07 May 2021 - 05:28 AM
Posted 11 May 2021 - 09:58 PM
I'm thinking of fitting a low oil pressure buzzer -
when driving , the oil light isn't really that noticeable , I tend to look for pot holes now a days & other cars
a buzzer would let me know instantly that something is wrong , either that or a fog light oil light
