Fitting A Quaife Diff
#46
Posted 05 June 2021 - 12:21 PM
Thanks Brad
#47
Posted 05 June 2021 - 12:35 PM
Thanks Brad
#48
Posted 05 June 2021 - 12:47 PM
it should just slide out.
use a magnet
#49
Posted 06 June 2021 - 05:41 AM
Thanks Guys,
That worked a treat once I removed the sleeve and ball bearing which practically fell out. Locked both gears and put a rattle gun on the mainshaft nut which must have been put on by Godzilla but all good now and I have my new pinion gear in place.
Happy thanks Brad
#50
Posted 07 June 2021 - 08:17 AM
bit late now, but personally I dont like to use rattle guns here, also the box should be locked in 1st and 4th as this gives the strongest combination (4th is straight through, and 1st has the most leverage ratio), I have heard of teeth coming adrift in other combinations.
#51
Posted 07 June 2021 - 10:15 AM
Box was locked in 1st and 4th isn't that the only way to lock a box?
I'm actually more worried now that I over torqued the nut because I used a 5 foot long torque socket which I had to dial down from 300lbs because it is usually used to do forklift split rims. No doubt I will be the next sucker who has undo that nut in the future ;-(
#52
Posted 07 June 2021 - 02:52 PM
#53
Posted 19 June 2021 - 10:05 AM
OK I have gearbox assembled to engine and I could turn the motor over and the output shafts moved accordingly, until I decided to wack the pot joints onto the output shafts. Now I can't turn the pot joints connected to the output Quaife diff shafts. Is this a problem, I used a piece of wood as a buffer between the pot joint and the hammer?
Thanks Brad.
#54
Posted 19 June 2021 - 11:30 AM
the pot joints should slide into the output covers with little effort - if you've had to hammer them in it might suggest the output cover bushes are not sized correctly for the pot joints
are they new pot joints ? i have a feeling there's been reports of needing to open out the output cover bushes a little when fitting new pot joints
#55
Posted 19 June 2021 - 12:16 PM
It's going to be hard now to do the tappets because I use to put it in second and roll the car to rotate the crank.
#56
Posted 19 June 2021 - 01:42 PM
So effectively uou are trying to turn the whole gearbox with the pot joint. Should be possible but with everything new could be a little tight. If the car is in gear you've probably got not chance.
For the tappets - in neutral, plugs out. Either a spanner on the alternator pulley nut, remove starter and turn the flywheel with a pry bar or with one wheel on the ground turn the other (much more mechanical advantage with the wheels on)
