Webber Carb For 1275/1310 Mild Tuned Road Engine
36 replies to this topic
#16 timmy850
timmy850
  • 3,615 posts
  • Local Club: MITG
Posted 01 June 2021 - 11:07 AM
Those Mangoletsi linkages are so cool! Unfortunately my budget doesn’t stretch that far!
Old ones in good condition were generally better quality. New genuine Weber ones are decent too, but some of the cheap reproduction non Weber ones are a bit poorly made.
If you aren’t in a hurry to get one right now, you might see a more appropriate one come up in the next few weeks/months
#17 Tones61
Tones61
  • 441 posts
Posted 01 June 2021 - 06:43 PM
Use the 45 with that linkage and that long inlet :-)
Looks like the same set up as on my spare 1293
#18 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 02 June 2021 - 08:48 AM
You have a spare engine 🤭🤭🤭
I did the deal on the 45!! My local classic car garage ‘old skool’ tunes Webber’s and when I have him the spec of my mild 1320 he advised the 45 straight away, with a 34mm choke (4.5 Venturi?) F2 emulsion tube?
The seller advertised the inlet as a Swan Neck but I don’t think it is. Been advised that steel ones run better, but if this one is ok it will do for now. Need to crack on and finish my cylinder head, build the subframe, drop the old one and engine, get a Webber bulkhead box and start cutting, welding and spraying. Summer holiday project will try and have it all done for Castle Combe??
#19 Tones61
Tones61
  • 441 posts
Posted 02 June 2021 - 02:44 PM
Pics of Weber box in bulkhead for Johnie alpha :-)
#20 Cooperman
  • 23,569 posts
Posted 02 June 2021 - 03:44 PM
What a neat job there.
#21 Tones61
Tones61
  • 441 posts
Posted 08 June 2021 - 05:01 PM
Hi Johnie alpha,
Post a pic of your new carb,
Looks a nice set up in your pm,
#22 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 08 June 2021 - 08:03 PM
Hi Johnie alpha,
Yer tis:
t3wmgak.jpg?1
#23 Tones61
Tones61
  • 441 posts
Posted 08 June 2021 - 10:00 PM
Looks same set up as mine on my green racer, mine was all 650 new, as in your pic, so you got a good deal dude :-)
#24 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 10 June 2021 - 04:00 AM
One thing I found, those Webers are LOUD! maybe not so bad if you have the box, but on a car with the open hole behind the speedo? Yikes!
Good luck with your project, but I've been really happy running HIF44's on my engines - I'll bet you'll get tired of the Weber on a street driven car. Wear earplugs if you go more than an hour away.....
#25 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 10 June 2021 - 06:13 AM
Will I?
https://youtu.be/EK2ijfxqlnY
#26 timmy850
timmy850
  • 3,615 posts
  • Local Club: MITG
Posted 10 June 2021 - 07:22 AM
I've done lots of long trips with a Weber & Dellorto side draft. We have bulkhead insulation blankets which helps, but it's definitely liveable for daily trips and the occasional long trip.
I mean if you did hours in the car every single day with a passenger that'd get a bit old, but for a fun weekend/road trip it's fine
#27 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 27 June 2021 - 05:18 PM
What size bulkhead box did you fit? Did you make it yourself or buy one.
I need to do the mod, but thought I'd make the largest enclosure I can to allow for good air flow around the carbs.
The only ones, I can find are these and these or these , although I thought RetroMinis had gone out of business?
#28 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 29 July 2021 - 11:07 AM
Tony,
Any chance you could post up the dimensions of your Weber Bulkhead box that you put the pics up of in this thread?
I am probably going to make my own, but need the dimensions to get it right.
I also need to account for any filter options I go for (yet to be worked out).
#29 Tones61
Tones61
  • 441 posts
Posted 29 July 2021 - 04:57 PM
Hi bill,yes I will get dimensions,I have put up pics on your Facebook thread :-)
#30 timmy850
timmy850
  • 3,615 posts
  • Local Club: MITG
Posted 30 July 2021 - 07:02 AM
You could also do a full length shelf like on some race minis!
