Oil Leaking From Clutch Housing and Supercharger Breather Set Up
71 replies to this topic
#31 sonscar
sonscar
  • 3,047 posts
Posted 20 July 2021 - 09:21 PM
Where is your brake servo getting vacuum from,as said above the breathers should vent into the inlet before the charger.Good eyeballing required I think.Steve..
#32 sam138
sam138
  • 509 posts
Posted 20 July 2021 - 09:34 PM
I’ve got the brake servo connected up as per below pictures as most others do on the supercharger, the servo still has the non return valve fitted as standard.
Should I connect up the crankcase, DSN filter on old fuel pump and rocker cover filter to the carb breather pipe directly as one ?
Attached File  642A6470-37C6-4EA4-9162-C99E4F5F961D.jpeg   99.43K   1 downloads
Attached File  655950F5-C986-45FF-8F39-310A3A4F22C7.jpeg   141.23K   4 downloads
Attached File  6C03D054-49B5-4A18-8D4E-5B18F712B4F9.png   317.23K   3 downloads
Edited by sam138, 20 July 2021 - 09:52 PM.
#33 sam138
sam138
  • 509 posts
Posted 20 July 2021 - 10:56 PM
I’ve got a suck through m45 supercharger set up and was wondering how people have piped up there breather systems ?
I was going to run the crankcase, rocker cover and the DSN filter ( on old fuel pump hole) and connect them all into the breather pipe on hif 44 carb ? Or should these all go to a catch can and block off carb breather.
Current set up below with crankcase breather to carb with stand alone filter on old fuel pump hole.
Reason I ask is that I’ve got oil leaking out of the clutch seal and I’ve seen a few people mention a build up of oil pressure with the supercharger cussing this.
Attached File  EEB63633-FE35-4DAB-ABB7-CF0B16C46AE5.png   317.23K   2 downloads
Attached File  BBB80F0D-986F-4FDF-BA9B-74743FBECB18.jpeg   141.23K   6 downloads
Attached File  373C2FC4-3140-42DF-8979-DDF1A4B2A340.jpeg   74.13K   3 downloads
Edited by sam138, 20 July 2021 - 10:59 PM.
#34 GraemeC
GraemeC
  • 7,440 posts
Posted 21 July 2021 - 05:58 AM
High oil pressure can NOT cause oil to push past the seal - there is no pressurised oil anywhere near it.
Still think you’re chasing a problem you don’t have. The compression test results are OK.
#35 sonscar
sonscar
  • 3,047 posts
Posted 21 July 2021 - 07:20 AM
I would connect all the breathers to the intake side of the charger.The crankcase should be under suction in a fit motor properly vented.Steve..
#36 Icey
Icey
  • 1,553 posts
Posted 21 July 2021 - 07:54 AM
You’re not putting boost pressure into the breather system, are you?
Edit: It looks like this question was asked before but I’m not seeing a clear response. Your breather system should only ever see vacuum.
I’ve got the crankcase breather connected to the hif44 carb and a DSN filter on the mechanical fuel pump with a stand alone filter, neither of these would cause boost pressure in the breather system would they ?
No, shouldn’t do. So I’d pull the flywheel and check/replace the seal.
#37 sonscar
sonscar
  • 3,047 posts
Posted 21 July 2021 - 08:55 AM
Is your oil filler cap vented?The breather system should draw a metered supply of air through a hole in the filler cap(which is a service item I believe)I would sort out the breather system first before pulling the motor but that is just my way.A few drips would lead me towards letting it develop as you say it was ok before charging it.Your car,your choice.Steve..
#38 Dusky
Dusky
  • 5,322 posts
Posted 21 July 2021 - 09:57 AM
Depends where it's hooked to the hif44 and if it's low through or suck through.
#39 nicklouse
  • 18,696 posts
Posted 21 July 2021 - 07:55 PM
All breathers should go to the low pressure side of the intake so carb or plenum.
#40 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 21 July 2021 - 08:06 PM
When the seal goes trust me you know, slipping clutch and oil pouring out of the split pin, not a drop, literally pouring out. Had a dodgy minispares seal fail on me this year, fitted correctly with the correct tool.
#41 sam138
sam138
  • 509 posts
Posted 21 July 2021 - 09:42 PM
Thanks for the reply’s, the set up is a suck through supercharger unit.
Just a bit of an update as I’ve added a rocker cover breather pipe and linked this into a Y piece with clutch breather and connected this to carb.
I’ve run the engine to normal temperature today and not one drop of oil is coming out now, do you think best to still pull the clutch and replace ? I’ve not physically driven the car as it’s off road at moment.
Attached File  4B0F6A85-4E11-4EEC-9B77-8888EC55E1DB.jpeg   131.1K   1 downloads
Attached File  965C6131-B1A7-4B67-98F1-707F6376EC56.jpeg   153.82K   4 downloads
Edited by sam138, 21 July 2021 - 09:43 PM.
#42 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 21 July 2021 - 09:46 PM
Connect everything from the right of the engine (as you look at it) to the rocker cover. Then connect the transfer case and rocker cover to a vented catch can. Block off the carb.
#43 Spider
  • 15,141 posts
Posted 23 July 2021 - 03:32 AM
I've merged your topics and changed the thread title as they are inter-related.
#44 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 23 July 2021 - 07:26 AM
Seeing more of your breather pictures, they're not big enough. The A series has a lot of turbulent air in it, ideally ½" ID from each of the breathers. I'm running a 1" pipe from the rocker cover to a catch can.
#45 sam138
sam138
  • 509 posts
Posted 24 July 2021 - 10:50 AM
Thanks for the reply’s, so I definitely shouldn’t have it all connected to the carb ? As a few have said this.
Steve, I was going to tee the crankcase and DSN fuel pump breather into the oil catch can then return via rocker cover feed ? Or should I have two holes in the rocker cover and tee on in with the crankcase as a breather ?
Edited by sam138, 24 July 2021 - 11:24 AM.
