Oil Leaking From Clutch Housing and Supercharger Breather Set Up
71 replies to this topic
#16 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 15 July 2021 - 10:21 AM
No image, host it on a photo sharing site and use the bb code
#17 sam138
sam138
  • 509 posts
Attached File  36392828-2E76-441F-A47A-547A1118DEEB.jpeg   164.7K   11 downloads
#18 sam138
sam138
  • 509 posts
Posted 16 July 2021 - 07:39 PM
Can someone advise the best item to purchase so I can measure the crank pressure? With the low pressure compression readings are we possibly saying I need a rebuild ?
Edited by sam138, 16 July 2021 - 08:16 PM.
#19 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 16 July 2021 - 10:16 PM
I have limited experience in turbo/ charged motors but on an N/A engine those figures are low enough for a partial strip...
However with the above said I strongly recommend a leak down test on all 4 cylinders to confirm if its valves or piston ring related.
I will let another member advise further but the above is what I would be doing before pulling the motor
Edited by cal844, 16 July 2021 - 10:18 PM.
#20 sam138
sam138
  • 509 posts
Posted 17 July 2021 - 09:03 PM
Thanks for the reply, is it possible that anything other than pistons and valve can be leaking during a compression test ? I didn’t isolate the fuel pump could this bore wash the cylinders as your cranking ?
How about my 1.5 rockers with 12 thou of clearance ? Should this be 15 thou ?
Also my boost gauge ( Tim’s turbo one) when you rev it stays in the minus figure all the time and doesn’t go positive to show the boost running.
Just trying to rule everything out like air leaks somewhere etc, I’m getting a leak down test kit ordered.
Edited by sam138, 17 July 2021 - 09:05 PM.
#21 Dusky
Dusky
  • 5,322 posts
Posted 17 July 2021 - 09:11 PM
Compression test numbers say next to nothing. Just make sure they're within 10% of each other. Too many variables; battery, starter motor health, throttle opening,...
But, being almost all identical, AND the results didn't go up a lot with oil in the bore, it seems like it ll be a healthy engine.
#22 sam138
sam138
  • 509 posts
Posted 18 July 2021 - 08:09 AM
Would something like this work to measure crankcase pressure? Looks to have a bung fitting that I can put in the dipstick hole.
https://www.amazon.c...e/dp/B075TYJ4WZ
#23 nicklouse
  • 18,697 posts
Posted 18 July 2021 - 09:11 AM
I would not waste the cash. Sounds like you have more issues.
where is the pressure sensor fitted?
you don’t mention what the cam is? Why did you set the clearance to 12 thou?
#24 sam138
sam138
  • 509 posts
Posted 18 July 2021 - 10:18 AM
I’ve got a boost take off fitted into the inlet manifold but don’t have a pressure sensor. clearance for tappets set at 12 thou after looking in Haynes manual but looking online it seems people with 1.5 rockers are setting at 15 thou ?
Cam is standard that comes with the Mini Cooper 1275 carb engine, the engine was running fine in NA form.
Surely as others have said I need to check crankcase pressure due to oil leak in clutch case ?
Edited by sam138, 18 July 2021 - 10:22 AM.
#25 Dusky
Dusky
  • 5,322 posts
Posted 18 July 2021 - 05:53 PM
Your compression test results don't point to a worn engine anyway. So that's good.
#26 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 18 July 2021 - 07:46 PM
Were your compression test results after installing the decompression plate? If so I wouldn't worry about them. If not then they're really low to me.
#27 sam138
sam138
  • 509 posts
Posted 18 July 2021 - 10:01 PM
Thanks for the reply’s, I’ve fitted a 6cc decompression plate which after calculating with an additional head gasket gets me down to 8.1 ish on compression, this was all fitted before the compression test was carried out.
So should I still proceed with a leak down test / crankcase test ? Or just simply pull the flywheel and inspect the leaking clutch seal.
Edited by sam138, 18 July 2021 - 10:04 PM.
#28 sam138
sam138
  • 509 posts
Posted 20 July 2021 - 08:28 PM
Just a bit of an update, I adjusted the 1.5 rockers to 15 thou clearance and redone the compression test ( dry ) on a cold engine and the psi increased !
Cylinder 1 - 125psi
Cylinder 2 - 125 psi
Cylinder 3 - 137 psi
Cylinder 4 - 130 psi
Looking online a fellow person who supercharged their mini had an issue with increased oil pressure and pushing oil out the clutch seal as per below. He fitted an oil catch can with an additional rocker breather all linked to the catch can. Does this sound like a better option than feeding pressure back to the carb from clutch case and an open filter on the mechanical fuel pump ?
https://www.diyauto....grahamxx/page/3
Edited by sam138, 20 July 2021 - 08:30 PM.
#29 Icey
Icey
  • 1,553 posts
Posted 20 July 2021 - 08:53 PM
You’re not putting boost pressure into the breather system, are you?
Edit: It looks like this question was asked before but I’m not seeing a clear response. Your breather system should only ever see vacuum.
Edited by Icey, 20 July 2021 - 08:57 PM.
#30 sam138
sam138
  • 509 posts
Posted 20 July 2021 - 09:17 PM
I’ve got the crankcase breather connected to the hif44 carb and a DSN filter on the mechanical fuel pump with a stand alone filter, neither of these would cause boost pressure in the breather system would they ?
Edited by sam138, 20 July 2021 - 09:22 PM.
