Rear Hub Nuts
34 replies to this topic
#1 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 02:39 PM
Hi,
Can anyone tell me if my ‘64 850 is likely to have reverse thread on the near side rear hub nut ? I just can’t get the darned thing off. It looks new, well greased, not rusty etc. Your advice will be much appreciated. By the way, the offside nut came undone easily 😳
#2 Chris1275gt
Chris1275gt
  • 959 posts
Posted 31 July 2021 - 02:51 PM
The rear n/s hub nut has a left hand thread so what would usually tighten it up loosens it.
#3 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 02:56 PM
Thanks but still can’t undo it, despite extension bar on socket etc. And yes, I took the split pin out first 😉
#4 nicklouse
  • 18,657 posts
Posted 31 July 2021 - 03:04 PM
All Minis have a Left hand thread on the rear arm on the left side of the car. UK near side.
BUT if some one at some time changed the stub axel it is possible the incorrect on was fitted.
you should be able to see enough thread to see though.
#5 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 06:37 PM
Thanks. I can just see some thread but working it out did my head in; I’m 52 you know 😅
I guess heat mustn’t be applied due to bearings behind, so now I’m stuck…
#6 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 06:46 PM
Can the castellated nut be drilled or split somehow ?
Edited by eebee, 31 July 2021 - 06:50 PM.
#7 sonscar
sonscar
  • 3,031 posts
Posted 31 July 2021 - 07:00 PM
Look at the axle end,if the thread slopes away to the right right hand thread.If it slopes away to the left left hand thread.Steve..
#8 nicklouse
  • 18,657 posts
Posted 31 July 2021 - 07:32 PM
AND? Same here.
you know how it should be. Try tightening first then undo.
#9 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 08:10 PM
It will not move either way 😬
#10 nicklouse
  • 18,657 posts
Posted 31 July 2021 - 08:19 PM
It will you just need to go for it.
#11 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 08:22 PM
I did, several times and even lifted the car off the axle stand whilst trying with fully extended 20” socket bar..
#12 Spider
  • 15,041 posts
Posted 31 July 2021 - 08:35 PM
Being where it is, you would be able to get a Nut Spliter in there. They normally remove the nut clean, but you will need a new nut.
Most Nut Splitters are flat, but there's some brands / types that have a small angle / kick on the cutting head. That would be the style you'd want.
Another way would be to drill a flat of the nut, putting say 3 or 4 small - around 3 mm - holes in a line down a flat, but don't drill right though - stop short. Then split it with a cold chisel. Be sure to thoroughly clean the bearing assembly once it's removed.
#13 Chris1275gt
Chris1275gt
  • 959 posts
Posted 31 July 2021 - 09:48 PM
Soak it overnight with some penetrating fluid get an extension on your 20" bar have the bar level with the floor sticking out beyond the boot and heave on it towards the floor, it won't lift off the stand and should undo. If no joy drill and chisel it off.
#14 eebee
eebee
  • 44 posts
Posted 31 July 2021 - 10:02 PM
Great, tyvm
#15 Tornado99
Tornado99
  • 750 posts
Posted 01 August 2021 - 02:38 AM
Heat it. If the bearings have a plastic seal, seal can be removed or replaced.
Also, an impact gun is usually successful as the vibes break friction lock from rust.
