Rear Hub Nuts
34 replies to this topic
#16 surfblue
surfblue
  • 1,827 posts
Posted 01 August 2021 - 06:15 AM
Never had any trouble removing a rear hub nut, assume a gorilla with an air wrench had been there before you.
#17 Spider
  • 15,042 posts
Posted 01 August 2021 - 08:50 AM
If it's frozen for reasons unknown, I'd suggest cutting the nut off by one of the methods mentioned.
Possibly, by trying to undo it, you may end up damaging the stub axle or the thread on it.
#18 eebee
eebee
  • 44 posts
Posted 01 August 2021 - 09:17 AM
Agreed on both counts. Gorilla with superglue and air wrench has made me decide to drill & carefully cold chisel the bastard thing off today; new nut on order.
#19 eebee
eebee
  • 44 posts
Posted 01 August 2021 - 10:48 AM
Drilled it off with no damage to stub axle thread, but… the inner bearing fell to pieces whilst using the hub puller. This car is fighting me all the way. Loads of black crud fell out with the ball bearings. I reckon the whole thing hadn’t been torqued, just done up so tight that the bearing seized & cooked itself to death. Fun.
#20 nicklouse
  • 18,657 posts
Posted 01 August 2021 - 11:12 AM
Cant really do them up too tight. As there is the spacer. And yes they often fall apart even when newish.
#21 Spider
  • 15,042 posts
Posted 01 August 2021 - 11:40 AM
Yes, but I've taken many of the older style apart that had no spacer fitted :ohno:
By the sounds of it, it was a balling bearing type and hasn't been apart in a while.
eebee, if the inner bearing is stuck on the stub, a puller is probably the safest thing to use here.
#22 eebee
eebee
  • 44 posts
Posted 01 August 2021 - 11:56 AM
Yes it’s a ball bearing type, or rather, was a ball bearing type. Should I replace with taper type or like for like ?
It’s the inner ring of the bearing left on the stub axle & that won’t budge either.
#23 Tones61
Tones61
  • 433 posts
Posted 01 August 2021 - 01:11 PM
Same as rolls Royce and most commercial vans/lorries,
Left hand side,left hand thread on their wheel fixings :-)
#24 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 01 August 2021 - 01:12 PM
Had that on a modern .. angle grinder on inner race to cut a slot and cold-chisel to split it. You don't need to cut too deep! It's under strain and may crack on its own!
#25 nicklouse
  • 18,657 posts
Posted 01 August 2021 - 01:14 PM
But would have had the spacer built into the races. As per the Metro/later design.
#26 Spider
  • 15,042 posts
Posted 01 August 2021 - 09:32 PM
You might need to purchase a Bearing Seperator to give the Bearing Puller something to latch on to in order to be able to pull the inner race, there's little there to grab.
I would suggest going to tapered rollers. My own experience with ball bearings, front or rear, is that when disassembling, they seldom come off in tact. If you are taking it apart to replace the bearing, then this isn't an issue, but say, on the rears, you need to get the brake backing plate off, it also means replacing the bearing too. The Tapered Rollers should also last you much longer.
The early Tapered Rollers and also the early Ball Rollers had a separate spacer as part of the assembly. It's that spacer I have found to be missing from quite a few assemblies. Usually when they came from a Workshop that seldom sees Minis. This is from the 1984 Moke Parts Book. All Mokes that were made here went to Tapered Rollers in all models from later in 1978.
I still have some of these assemblies, if I remember, I'll snap off a pic.
#27 nicklouse
  • 18,657 posts
Posted 01 August 2021 - 09:34 PM
No spacers
Attached File  5D076407-EB19-4760-B795-949BFAB467C0.png   265.71K   4 downloads
ok front but same.
#28 Spider
  • 15,042 posts
Posted 02 August 2021 - 12:57 AM
No spacers
Yep, that's why I also included;-
#29 Rorf
Rorf
  • 866 posts
Posted 02 August 2021 - 12:42 PM
We talking about a 64 model mini so it would originally have been fitted with ball bearings and spacers. I would always replace these with Timkin taper bearings; ball bearings are a pain as they always fall apart when removing.
#30 Spider
  • 15,042 posts
Posted 05 August 2021 - 07:26 AM
Promised Photo of the earlier Rear Timken Assemblies
There's also a Factory Reference to these Bearing Assemblies having a separate spacer here;-
