Rear Hub Nuts
34 replies to this topic
#31 eebee
eebee
  • 44 posts
Posted 07 August 2021 - 06:12 PM
Well folks, I used my Dremel & a mini diamond disc cutter to remove the inner bearing sleeve. Then fitted a new taper bearing set & new castellated nut. All good now & thanks for all your helpful advice. Iain
#32 Tornado99
Tornado99
  • 750 posts
Posted 08 August 2021 - 04:50 PM
How long did it take to dremel? I was advised to not attempt with dremel and use an angle grinder instead.
#33 Spider
  • 15,042 posts
Posted 08 August 2021 - 08:56 PM
I think you could use either, the mail thing here is not to damage the stub axle, otherwise it goes from being a few hour job to an all day ordeal and cost a fair bit more. I wouldn't class my Angle Grinder skills as good, so, while a bit expensive to burn through a few Dremel Cutting Discs, I think if I was to use grinding as a method here, I'd be inclined to use a Dremel and take my time doing it. To be honest, I'm probably more of a Cave Man so I've done these by drilling a couple of small holes in the nut then using a Cold Chisel that I can bash with my Club, though now days, I have a Nut Splitter.
#34 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 09 August 2021 - 11:53 AM
I have a cheap & small 75mm grinder so much easier to handle .. and a 100mm and 115mm!
#35 eebee
eebee
  • 44 posts
Posted 12 August 2021 - 01:16 PM
Dremel with discs at about a £1 each was excellent and very controllable. No damage to stub axle or hub/backplate. Obviously wore goggles but no dramas, just a few sparks.
