Tachometer Problems
electrical
3 replies to this topic
#1 Slyrange
Slyrange
    Starting My Mini Up
  • 2 posts
Posted 07 August 2021 - 06:02 PM
Reliant-Scimitar-Se5-5A-Tachometer-Rev-C
I've recently been looking for a Smiths tachometer to match the rest of the clocks and picked this up for £20. I thought it was a steal honestly. The trouble is, it's for a 6 cylinder and with my 998 engine being 4 cyl, the rev needle wouldn't be accurate. I was wondering if there would be any way of converting this tachometer to measure a 4 cyl instead.
I've thought about putting a cheap gauge behind it and just sticking the smiths plate on the front but I don't want to risk breaking anything.
The model is RCV 2613/00F
#2 richmondclassicsnorthwales
  • 942 posts
Posted 07 August 2021 - 07:47 PM
Calibration is different
#3 Spider
  • 15,245 posts
Posted 07 August 2021 - 08:30 PM
From memory, every Smith Tacho I've taken apart has had a Pot in them for Calibration. I'm unsure if it would have sufficient range to take it from 3 pulses per rev to 2 pulses.
4 Cylinder types in that style, I would think would be much easier to come by than 6 cylinder ones. Maybe get in touch with a MG Group (and what other cars may have used these) and see if you can swap it for a 4 Cylinder type. Personally, I like modifications, but I like them to look finished and manufactured. I note on the face of this gauge, it says '6 Cyl', that would bug me every time I got in the car. I'd suggest this as a first option.
If you do want to go down the road of re-calibration, even if there's not a pot or not enough range in the pot, it would still be possible, there's 'pulse changers' available for this or it would be possible to change a couple of internal components to get the outcome you're looking for.
As a final check / calibration of it, find a Mains Power to 12 V AC Power Pack (or just a small transformer will do if you can look after the safety aspects). Note that most Power Packs are DC. That's no good here, it must be AC, though a DC one as well would be handy. Connect the Tacho up to power it up, then connect the AC Power Pack between Earth and the Points connection of the Tacho. As you live in the UK, adjust the Tacho until it reads 1500 RPM.
#4 Vanman20
Vanman20
  • 274 posts
Posted 08 August 2021 - 01:10 PM
I've put a Smith's rev counter out of a  4 cylinder Triumph into my Mini and it reads about half what it should.
I have it wired direct to 12v rather than through the voltage stabilizer,I keep meaning to rewire it to see if that fixes it.
You can buy aftermarket rev counters that are switchable between 4,6 and 8 cylinders
