Dash Rail Gap Dimensions And Window Aperture
Best Answer gaspen , 17 September 2021 - 07:35 AM
No problem gaspen! Really appreciate the help!
It should get me close enough even with the windscreen in. Just need it from the panel where the sun visors are bolted to the roof to the dash rail top
Here we go :
Measured outside at the outer edge of the rubber : 425mm
(The bodywork catalog suggest 435 mm here but the windscreen still fits  :lol: )
[attachment=214612:ws1.jpg]
Inside :
[attachment=214613:ws2.jpg][attachment=214614:ws3.jpg]
Go to the full post
26 replies to this topic
#1 hulsmeier
hulsmeier
  • 158 posts
Posted 14 September 2021 - 09:47 PM
Hi all
Apologies if this is already been said 100 times but I can't find this anywhere.
Does anyone have the dimensions for between the upper and lower dash rails at both ends and the middle?
Also for the windscreen aperture gap (414.5mm or near), is that from the lips or the top of dash to the bit behind the window lip at the top?
I'm having difficulty fitting my window and have a feeling the upper dash rail is out.
Should the windscreen rubber fit flush to the tip of the upper dash rail or should there be a gap?
#2 gaspen
gaspen
  • 1,193 posts
Posted 15 September 2021 - 05:07 AM
Maybe this drawing help a little.
I think 414.5 is good if you measure beetween the edges. On my car there is a small gap at the upper dash rail, approx. 5mm
Are you trying to fit the same windscreen back to the car or want to fit a new one ? Was there any bodywork on the front ?
I installed my glass some weeks ago and it was pretty hard to stretch the rubber, especially in the last corner.
Attached File  kaszni méretek szélvédÅ‘.jpg   20.98K   37 downloads
#3 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 11:06 AM
Thank you gaspen
I was trying to fit the original screen however it cracked last night.
The car has had body work done to the front including the scuttle. However I measured before and made sure these measurements were correct when welding. Although it seems the measurement I had wasn't near the 414.5mm, which makes me suspect the scuttle I replaced wasn't original.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 15 September 2021 - 12:07 PM
Even if the scuttle is Heritage you need to be wary about the corner radius’s.
I checked on my clubby before and after a found a small discrepancy that could have made things interesting. This was linished back so hopefully come the windscreen install I shall be good to go.
It’s as couple of mm and this was the mating flange to dash rail. Never assume that Heritage is as per the factory dimensions. Presses and former are getting older and worn. Measure twice, weld once.
#5 gaspen
gaspen
  • 1,193 posts
Posted 15 September 2021 - 12:44 PM
That is why I braced the windscreen aperture, but it's too late for you...
Please note that the measurements on my drawing is NOT from edge-to-edge !
Isn't there another Mini in your area to check the measurements ? As I remember the height of the glass is ~395 mm, so it should fit into that aperture together with the rubber.
#6 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 01:23 PM
Fitting the window in the aperture without the rubber, there looks to be plenty of room it was just getting the last two corners in. I still have the ability to move the dash rail if I have to. I did brace the lower dash rail thankfully but would still like to check the dims.
No other mini I know of in my area
#7 gaspen
gaspen
  • 1,193 posts
Posted 15 September 2021 - 02:46 PM
Exactly as for me. It was my first windscreen install and I struggled with it, especially in the corners.
Do you have a tool ? Did you install the rubber to the aperture first, then the glass ?
I made a tool by myself, similar to this on the picture. With this tool I could stretch the rubber to the edge of the glass. Be aware not to touch the glass with the tool.
In my case the glass slided to one side, out from the rubber. You should push it back with your palmar to help the fitting on the other side.
Attached File  s-l400.jpg   10.46K   4 downloads
#8 Vanman20
Vanman20
  • 274 posts
Posted 15 September 2021 - 03:16 PM
I've seen it mentioned before that on a Mini you fit the seal first and then pop the glass in which goes against everything I was taught which is to fit the seal to the glass and use the string method of install.
Which is correct ?
#9 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 04:10 PM
I don't have a tool but will have a look for one looks like a great idea.
I've just trial fitted the dash and finding that the demister vents aren't fitting in the right position. I assume these are supposed to slide under the seal.
It looks to me like the dash rail is too high, this would push the rubber up too so could be leading to all the issues.
Must note that when I measured the aperture the bulkhead part was sticking up the highest so I don't think the issue is with the aperture but more likely the dash rail behind
#10 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 04:11 PM
Just to add to the above when the plastic demisters are fitted they seem to be blocked by the dash rail
Will grab a snap!
#11 gaspen
gaspen
  • 1,193 posts
Posted 15 September 2021 - 04:14 PM
#12 gaspen
gaspen
  • 1,193 posts
Posted 15 September 2021 - 04:18 PM
Will grab a snap!
Could you take same picture ?
#13 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 04:42 PM
Which is correct ?
Sorry Vanman 20 missed this earlier.
When I have done this in the past I have used a cord but put the rear window in by hand the other night. Front window is causing a prob as I have a new front end on now
#14 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 05:06 PM
having trouble uploading these.
please try the links
https://imgur.com/D61wL23
(vent left cover - ok on left hand side begins to block vent as it moves towards centre)
https://imgur.com/6PbaIxU
(right hand side with dash pad - looks like gap is ok on right but tapers towards centre)
https://imgur.com/Dc1nkYl
(right hand vent (slightly mangled -  blocking vent hole and lip doesn't fit inside cut out within the cover)
https://imgur.com/nXpFewh
(gap between windscreen rubber and top of dash rail right hand side)
https://imgur.com/OTRfZWK
(dash rail pad centre - does not fit very well under seal)
https://imgur.com/oThLZu9
(left hand side with dash rail pad - gap apparent but lessens towards centre)
https://imgur.com/XNPeALO
(another of cover over right hand vent - note the lip on the rail does not fit within the vent cover)
https://imgur.com/xO01mpM
(centre windscreen to dash rail gap (or lack of?))
https://imgur.com/hoQzCe4
(gap between dash rail and window rubber left hand side)
I hope these work
#15 hulsmeier
hulsmeier
  • 158 posts
Posted 15 September 2021 - 10:20 PM
If possible can anyone confirm the distance between the top dash rail (before the lip) and the roof (where the sun visors are mounted)?
If I can confirm this it will help me determine if the top dash rail is in the correct position
