Suspension Part Name?
suspension
Best Answer Homersimpson , 22 November 2021 - 09:26 AM
As above its the shock absorber top bush which will come with a new shock absorber when you buy it.
Go to the full post
10 replies to this topic
#1 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 22 November 2021 - 03:59 AM
Hi Guys,
Could you please tell me the name of this part?  I can't find it in my Haynes manual, though I see the part in a picture for Chapter 10 Suspension, section 17-4.
We're replacing all the shocks, and the bolt for the right rear shock needed to be sawed off, so I had to cut through the rubber part whose name I can't find.
My guess: Hydrolastic Displacer
https://www.7ent.com...er-21a1496.html
Thanks,
Ryan
#2 Spider
  • 15,250 posts
Posted 22 November 2021 - 04:52 AM
It's either the top stud of the rear Shock Absorber or the top stud of the Helper Spring, depending on the model of your Mini. Hopefully, it'll be the former.
#3 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 22 November 2021 - 05:49 AM
Mine's a 1962 Austin Mini
#4 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 22 November 2021 - 05:54 AM
Here's the picture from Haynes.  It's that rubber bit below the metal ring.
https://ryanlogsdon....mini/haynes.png
#5 croc7
croc7
  • 823 posts
Posted 22 November 2021 - 06:30 AM
From your description, ‘the rubber bit below the metal ring’, its the rubber bushing supplied with the shock absorber.
#6 Homersimpson
Homersimpson
  • 840 posts
Posted 22 November 2021 - 09:26 AM   Best Answer
#7 nicklouse
  • 18,767 posts
Posted 22 November 2021 - 09:42 AM
Hi Guys,
Thanks,
Ryan
The displaced is in the subframe.
if a hydro car it will be the mounting for the helper spring.
#8 GraemeC
GraemeC
  • 7,452 posts
Posted 22 November 2021 - 09:55 AM
Or the shock if its been upgraded (although this is only usually done at the front, but who know what's gone on in the past).
He does say "the bolt for the right rear shock needed to be sawed off" so there's a chance it not on hydro.
Edited by GraemeC, 22 November 2021 - 09:58 AM.
#9 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 22 November 2021 - 06:29 PM
Thanks everyone! The rubber pieces in my Bilstein package are just a different shape
https://usa.minispor...orber-each.html
I'll use what's in the case.
#10 nicklouse
  • 18,767 posts
Posted 22 November 2021 - 07:39 PM
Those are front shocks.
#11 Spider
  • 15,250 posts
Posted 22 November 2021 - 07:40 PM
These are what you need for the rears;-
https://www.minimani...-Shock-Absorber
Also tagged with one or more of these keywords: suspension
