ah just seen all the added tests above, will try tomorrow. Thank you everyone that took the time to respond.
Electronic Ignition
#16
Posted 30 November 2021 - 08:01 PM
#17
Posted 02 December 2021 - 12:15 PM
Hi All,
Been out and spent a little more time today.
Coil and Distributor have been tested and working fine.
However still no spark when all is connected to car.
I have it hooked up to a large pickup truck for testing, and measure 14.5v at the starter main feed, and then on to the fuse box etc just fine. Same at the distributor module feed etc.
One thing i have noticed is that when i turn the ignition key, the voltage at all points drops to 9v whilst cranking, before shooting back up to 14.5 when not.
My ignition switch is a little old a worn, but will turn the engine over consistently, so despite the ignition lights flickering as you move the key, it seems to do the job (unless you tell me otherwise etc).
Now i have ready that the module needs consistent 12v to function, so can only presume that the voltage drop is rendering the module useless during cranking, hence no spark, so does anyone have any reasoning / suggestions for the voltage drop.
I know this is a 998 car, so will have had ballast ignition, so 9v would have been ok?, but as im feeding the coil and module direct from the fusebox, there should still be 12v getting through.
Sorry for the long post, but not sure where to go next.
thanks
Nick
#18
Posted 02 December 2021 - 12:24 PM
The drop to 9v is concerning. Check your earth straps.
#19
Posted 02 December 2021 - 12:25 PM
The voltage drop is normal, when the motor's turning it makes a big voltage divider with the rest of your electrics.
https://www.theminif...agnosis-repair/
#20
Posted 02 December 2021 - 01:30 PM
Hmm, two earth straps are in good order, and the starter is turning at a decent speed.
So question is, if 9v is normal (IE entire car receiving 9v while cranking), how do you get 12v to the module to keep it working?
thanks
Nick
#23
Posted 02 December 2021 - 06:33 PM
thanks
Nick
At 9V, it's just on the cusp of being to low / just enough voltage for the Electronics.
Some causes, as already mentioned, is bad earth connections - check the one on the battery too, battery is on the way out or not charged enough, poor main battery cable connection, starter motor on the way out.
#24
Posted 03 December 2021 - 12:22 AM
I know my old system didn’t like under 10v, and I had to rewire to get more power direct to the module
#25
Posted 03 December 2021 - 09:02 AM
Ok thanks guys, will get out there and have another go.
Nick
#26
Posted 30 March 2022 - 01:22 PM
Checked tdc
Checked dizzy drive is correct
New powerspark distributor coil and leads
New battery
Still no spark, scratching head again, any more ideas?
Have good 12v everywhere, and good earth at all components.
My brain is scrambled
#27
Posted 30 March 2022 - 01:47 PM
Hello all, me again. Sorry for the delay but u had a stroke on 19th December, anyhow I got back out there recently, and have since done the following
Checked tdc
New battery
Not good to hear about the stroke, the good news is you're recovering well.
Id now resistance test the coil (there's a how to in the FAQ section)
#28
Posted 30 March 2022 - 03:13 PM
#29
Posted 30 March 2022 - 06:32 PM
Sorry to hear of your stroke, I sincerely hope you have pulled up OK from that with no added complications.
Not sure where you are measuring the voltage, you'll likely need an assistant, but measure also direct at the battery while cranking, it could be a battery that has a high internal resistance. Also, just to double check that the voltage drop is the issue, if you have another 12V battery (even an alarm battery), disconnect the car's loom from the ignition system and connect this in to check it will start and run.
#30
Posted 31 March 2022 - 12:15 PM
I'm ok, I was real lucky, but off work and not driving yet so loads of time
