Pistons For 1330
19 replies to this topic
#16 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 08 January 2022 - 01:38 PM
Yeh, Gavs mini Estate. He doesn't know what power its running, but the timing is very safe.
I like that. Low CR has always put me off charging
#17 A1111j
A1111j
  • 77 posts
Posted 09 January 2022 - 03:04 PM
Question I am using a compression ratio calculator and when I put all measurements in there it gives me 9.56 but if I just change the bore size from 1330 to a 1293 and the rest the same the compression ratio drops to 9.35 is that right? Although I am getting a marginally more cc in bore?
#18 KTS
KTS
  • 2,490 posts
Posted 09 January 2022 - 04:12 PM
going from 1330 to 1293 is reducing the bore, so less cc (swept volume) not more
assuming unswept volume doesn't change, then compression ratio would drop as swept volume decreases
#19 mini13
mini13
  • 3,811 posts
Posted 09 January 2022 - 04:36 PM
That's the one, I thought I remembered 150hp mentioned, I must be thinking of somthing else.
#20 A1111j
A1111j
  • 77 posts
Posted 17 January 2022 - 07:32 PM
Update guys finally found a solution. so engine is getting liners and bored to 1293 and gonna fit 18cc +20 forged pmega pistons. if I get the piston flush to block deck I will get a compression ratio of about 8.46 that mean I can run abit more boost in the future if need too.
