Ball Joint Rebuild Kit
#16
Posted 05 February 2022 - 12:50 AM
#17
Posted 05 February 2022 - 04:54 AM
Is it possible to buy just the nylon cups?
Not that I'm aware of. The maintenance free joints aren't an adaption from the original joint, but a complete unit. As you know, when you take an original type from the packet, there's many separate and for all intents, interchangeable parts - the Pin, Cup, Seat, Spring (for the lower joint), Seal, Lock Washer, Shims, Nut and Spring Washer. These maintenance free joints are the Joint itself, the Lockwasher, Nut and Spring Washer. Included too is a Hex (Allen) Key. The Joint for all intents, doesn't come apart. The Hex Key fits inside the top threaded end of the Pin, presumably to enable the assembler to hold the Pin fast, while tightening the Nut. I didn't find this an issue what so ever, perhaps though, if the Nut was a Nyloc type, the Hex Key might be handy.
On looking at and thinking about the original style joints, the factory fitted originals (these were made by TRW), were an appropriate grade of steel and hardened in an appropriate way. I always found, as long as there was some grease in them, they'd basically last forever. The current range of replacements are no where near as hard as the originals, and the depth of hardness is considerably less. On thinking about the make up of these and how they 'wear' or rather fail due to scoring / scuffing, I feel these would fair WAY better fit at the very least, the Seat in them was a much softer material, like one of the wonder plastics that are used in just about every other ball joint fitted to most other cars out there.
#18
Posted 05 February 2022 - 08:29 PM
Are these the same ball joints?
yes he get them from David in Japan also their rubber boots and Gaiters are far superior to the british crap
#19
Posted 06 February 2022 - 08:24 AM
Actually had some that split taking them out the plastic bag they come in...
But they were cheap, customer supplied...... thankfully he was there when it was opened...
Love working on folks cars when they are over your shoulder telling you what to do...
#20
Posted 06 February 2022 - 10:24 PM
I have had the Jap items on for 5 years with no probs
