1275 A+ Setting Cam Timing Standard
18 replies to this topic
#16 Mxrab
Mxrab
  • 22 posts
Posted 27 February 2022 - 10:14 PM
#17 Spider
  • 14,867 posts
Posted 27 February 2022 - 10:42 PM
Thanks for the info and in particular, the photo.
There is actually a 'ring' machined in to it between the 1st and 2nd lobes. This is the most common type of 1275 A+ Cam used.
Inlet is fully open at 107.50 ATDC with these.
Timing figures are;-
Inlet Opens 90 BTDC
Inlet Closes 410 ABDC
Exhaust Opens 550 BBDC
Exhaust Closes 170 ATDC
Lift at the Lobe is 0.250"
Lift at the Valve is 0.318" (with stock rockers)
Note that the checking clearance (to see these numbers) at the Valve is 0.021" with the standard sintered type rockers.
#18 Mxrab
Mxrab
  • 22 posts
Posted 28 February 2022 - 02:40 PM
Well Iv learned something new today, really appreciate the help Spider, thank you. Based on the inlet opening at 107.5 ATDC that means that the dot to dot is out by 4.5 degrees based on my 111 degree calculation? So I need a 4 or 5 degree offset key to bring it back into line.
Inlet Opens 90 BTDC
#19 Spider
  • 14,867 posts
Posted 28 February 2022 - 05:35 PM
Up to you, but many, including myself, usually advance the initial Cam setting by 1 to 20 to allow for Chain settling and for some, initial stretch.
