Crankcase ventilation is something that seems to be little understood and so easily over looked.
As the engine runs, in pulses, it will want to breath in and out. As you get some ring blow-by, this will want to pressurise the crankcase and should do so, only slightly - should.
The engine temperature also changes as it runs. When you shut it off after a run, it will tend to increase in temperature briefly, then cool off.
All these add together to cause the crankcase to breath.
Oil is hydroscopic, so it will also absorb some water (moisture) + in some conditions, you can has a small fog on the crankcase. The Blow-by and Moisture combines with the Oil and becomes slightly to considerably acidic.
Crankcase Ventilation deals with all this.
Most systems will draw in fresh air via a filter and some with a valve (to only let air in). This circulates through the crankcase and then is usually drawn off to the Manifold, often via a PCV Valve, which meters the flow and will also shut it off in a reverse flow, or as in the case with the post 71-ish Minis, a CCV System (Closed Crankcase Ventilation System). As well as circulating air through the Crankcase to remove the Moisture it also draws off fumes from the Blow-by so the engine doesn't smell. They also usually reduce the Crankcase Pressure to below that of Atmospheric, which has a tendency to reduce oil leaks.
The CCV System the Factory fitted to these cars, when looked at in very close detail is one thing I feel the factory got totally spot on. For just about any street car, except maybe in boosted applications, in my opinion, you won;t get a better set up.
I’ll happily admit I am one who doesn’t understand loads about crankcase breathing, although the above has certainly been very helpful.
I do have one question though, any ideas why the problem has suddenly got quite large? Last year it didn’t seem to be a issue running set up like it is.
