Posted 04 June 2022 - 08:01 PM
Posted 04 June 2022 - 08:32 PM
Have you actually checked the temperature by other means?
IIRC. That is just casting flash in part of the water jacket. If I am seeing what I think I am. It is far away and not well lite.
Posted 04 June 2022 - 09:03 PM
I took quite a few measurements with an infra-red gun (at a point on the engine block just below the thermostat housing), it agrees reasonably well with what the temp gauge is saying.
I've added what is hopefully a clearer photo below, a screwdriver can be poked right through the hole into a cavity. I'm not sure where the cavity leads to though.
If it's usual to have the hole there that's great, it just means I'll have to look elsewhere to solve the overheating (coolant passages or head gasket perhaps).
mini water pump detail.jpg 47.72K
6 downloads
Edited by zero_wlv, 04 June 2022 - 09:35 PM.
Posted 05 June 2022 - 12:14 AM
Posted 05 June 2022 - 12:20 AM
That ain’t a problem.
Posted 05 June 2022 - 06:46 AM
Maybe you just need to give the block, heater and radiator a good flush through with a hose pipe in both directions if you are getting a lot of rust in the coolant. It might be worth checking with your heat gun the temperature over all the radiator as it might be sludged up and need replacing.
Posted 05 June 2022 - 11:29 AM
There's coolant jackets all around the cylinders. Even if that was another hole, that should not affect cooling. 100 degree is a tad too much, but nothing extraordinary.
Does it go higher, and actually boil?
Is everything else correct? Fan correct way around?
It creeps up above 100deg and looks as though it's not gonna stop, I've bailed out at 105 every time and pulled over! So it hasn't actually boiled as such, but I'm sure it would if I carried on driving.
The fan is definitely the correct way (ribs facing the outside).
I already tried flushing it a couple of times (once with Wynn's rad flush, once with white vinegar and also plenty of water) but I'll give it another go.
Would there be any point in taking the head off and poking through the coolant passages with pipe cleaners?
Posted 05 June 2022 - 01:36 PM
You could pull the head, but if you are not getting a lot of sludge when you have previously fushed the system, it would probably be pointless
Posted 05 June 2022 - 07:26 PM
I just spent a couple of hours pulling the head :)
I'm not really sure what the photos are telling me, I'm not experienced enough, except perhaps that everything could do with de-coking and one of the exhaust valves looks lean.
I don't know if there's anything that could cause overheating.
(p.s. the engine's only done 6400 miles since it was reconditioned, although it looks like a lot more!)
BLOCK WITH GASKET:
block with gasket.jpg 72.06K
11 downloads
BLOCK WITH GASKET TAKEN OFF:
block without gasket.jpg 76.4K
14 downloads
HEAD:
head 1.jpg 62.68K
19 downloads
HEAD DETAIL:
head detail.jpg 76.35K
9 downloads
BLOCK DETAIL:
block detail.jpg 74.45K
6 downloads
Edited by zero_wlv, 05 June 2022 - 07:29 PM.
Posted 05 June 2022 - 08:31 PM
Posted 05 June 2022 - 09:25 PM
Looks like you have a recessed exhaust valve or two there.
Posted 05 June 2022 - 09:50 PM
I'm not really sure what this means, what are the implications of it?
When I bought the reconditioned engine it was described as "high compression", although I believe this was achieved by using high compression pistons.
It's a 12G940 large valve cylinder head (off a 1275cc?) on a slightly overbored 998cc block.
Posted 05 June 2022 - 10:20 PM
The head, yes 1275, needs a recondition. Or at least looking at by someone who knows the A series build.
one exhaust valve seems to be sitting low in the head. This could be wear or could be intentional to aid the clearance to the block where it may not have been quite pocketed enough to give clearance.
Posted 05 June 2022 - 10:32 PM
Make sure when you you put it back together you use a 1275 head gasket. A small bore gasket will partially cover pockets that have been machined in your block. The 12G940 you have head is normally fitted to a 1275 engine and the valve spacing is wider to that on the small bore engines hence the pockets to give the exhaust valve clearance on your engine.
Posted 06 June 2022 - 06:24 AM
I can't say with any certainty but that hole you've found may have some impact on the cooling as the pump does rely on the shape of the casting in the block to direct the coolant from the impellar correctly. I wouldn't be too fast to write that off. You maybe able to prove it by re-building it with one of the plastic metals.
Some other common causes of running hot are;-
rusted cooling jacket
chocked cooling system
blown head gasket
incorrect timing and / or advance curve
incorrect fuel mixture (carb needle)
vacuum leak
cracked head
cracked block
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
