Specialist components sell forged A+ rods... guess where they get them from ;)
Tell us Steve.
Oh, i thought it was obvious.. maxspeeding.
The old version, or the latest ones too?
Posted 06 January 2023 - 01:31 PM
Tell us Steve.
Posted 06 January 2023 - 05:02 PM
For some people, Maxpeeding is not a bad option.
http://mk1-forum.net...php?f=5&t=27556
Link not working
Because it's a link to a rival forum, that's probably not allowed?
No, that;s fine. It's odd that it doesn't work. I did a search on the MKI Forum and found this thread;-
http://mk1-forum.net...6&p=236194
The notes and remarks about these and similar cheap rods is worth reading along with those regarding the Saenz Rods, which are in my view, a decent rod.
As best I've been able to determine, the cheap rods are made by sintered process, which is common-ish among some OEM car engines these days, they can be quite a strong and decent rod, however, the process involved is highly specialised and easy, very very easy to get wrong. These rods too, can't be 're-worked' or reconditioned, once they go out of spec, it's a bin job, they can't be closed and honed on the big ends, they can't be straightened when bent or twisted (assuming they survive that in the first place), all those I've seen need modifications to the block to give clearance for them to fit and most are a straight rod, not off set like stock rods. Most also need odd sized gudeon pins.
Quality rods, like the Saenz, Arrow, Carillo etc are forged, like the originals were and hence why they cost so much more. These can be re-worked and reconditioned, just like the originals.
Posted 06 January 2023 - 05:49 PM
Posted 06 January 2023 - 06:14 PM
Posted 06 January 2023 - 06:56 PM
In truth, for road-car engines, the A+ rods are fine. If balanced and, if you feel it necessary, polished to remove any stress-raisers, they are good for 8500 rpm. If you are racing and will be using a sustained 8000 - 8500 rpm, then maybe special rods are a good idea, but not many people on here rev to much over 7000 rpm.
The rods to avoid are the A-series rods with the 'lumps' on the big-end caps. Avoid these. Innocenti 1300 rods are also very good abd are strong.
But then, if money is of no importance, that's a different matter.
It's the same with pistons. The 21253 is just about the ideal piston for a road car revving at up to 6500 rpm, but those selling them will claim that a forged piston is necessary. Modern squeeze-cast pistons are very strong.
Posted 06 January 2023 - 07:03 PM
While we are on about rods and how they may or may not be good enough, i follow a chap on Youtube called Steve Morris Engines. He is an exponent in Billet Aluminium engines and builds some absolute monsters. (Yes its predominantly V8 turbo charged monsters, but also Supercharged and he also makes Billet Lambo blocks as well)
One of his videos shows his drag car where he had an 8 piston delete episode. All 8 connecting rods shattered and i mean shattered, and after he had some metallurgy carried out he got to the bottom of why.
Posted 06 January 2023 - 07:17 PM
Edited by imack, 06 January 2023 - 07:20 PM.
Posted 06 January 2023 - 07:32 PM
Steve Morris's billet engines are absolutely stunning and the destruction of those rods was mental.
Was fantastic watching him repair that billet block.
Yep, a good design enabling repairs to be carried out which on a normal engine would have been so much scrap. BUT at $98k plus you would hope there would be something that could be done repair wise. His SMX and SML engines are something else.
And his Caprice is mental.
Posted 06 January 2023 - 08:10 PM
Posted 06 January 2023 - 08:46 PM
Edited by imack, 06 January 2023 - 08:50 PM.
Posted 06 January 2023 - 09:10 PM
I enquired with MED 6 or 7 years ago about getting standard rods lightened, balanced, sized and ARP bolts fitted but was told it would end up almost as expensive as buying high quality aftermarket rods and would be nowhere near as light or reliable.
I think lightening standard rods is a dying art these days as superior rods are now readily available off the shelf.
MED machined some material from the big ends of my A+ rods, no idea how much weight it took off but I wouldn't imagine it was more than a few grams. I forget how much it cost.
Posted 06 January 2023 - 09:53 PM
I started getting into his youtube channel a few months ago when he made a big block for Cleetus's Alco. The thing is a work of art!
Posted 06 January 2023 - 10:11 PM
Cleetus's Elco has come on since he decided not to turn it into a jet car and then he gave the car to Kevin of KSR fame to turn into a full blown drag car. However Tom Bailey was the chap i follow who runs a couple of Steve's SMX engines who drew me to Steve.
But i digress, even the best looking rods can be utter junk if not made from the correct material. I'm running A + rods with Omega pistons and one of Oz's bladed and wedged cranks in the bottom of my 1293 Billet Ali 7 port. Oz will have done some work i'm sure to the rods etc as a lot has gone into the block. Considering the cam i'm using is one of Keith Calvers with pwr range of 2500 to 7500+ rpm i'm happy to stick to the A+ rods.
Posted 06 January 2023 - 11:31 PM
Everyone is fitting them on their cars.
I wouldn't say 'everyone' but in most cases, the people I have spoken with regarding their purchase and the reasons for buying them comes down to cheap bling. If your heart is set on them, knock your socks off ![]()
and I'm not the only one to call them out for what they are !
I have some photos, I'll find them and post them up.
