Japanese Balljoints From Minispares
43 replies to this topic
#1 unburntfuelinthemorning
  • 1,990 posts
Posted 27 January 2023 - 06:20 PM
About time.  Bit pricey though.
Are these the same as the ones from Guessworks?  Those are far cheaper.
http://www.guess-wor...play.htm?id=611
#2 Shooter63
Shooter63
  • 1,079 posts
Posted 27 January 2023 - 08:00 PM
I can't imagine that there are many companies making sealed ball joints, so I expect they are the same. I bought a new set of ball joints and they were so far out of spec, I binned them and bought a set of guessworks ones, job done.
Shooter
#3 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 27 January 2023 - 08:14 PM
There’s also the original type ones from Japan which are about £40 each at the current exchange rate. I believe from previous posts they are different to the Guessworks ones
https://classicminis...ee-ball-joints/
A recent post by David at CMJ confirms Minispares are selling the same ones as him
Minispares have a photo on Facebook and they are stamped “Mini Delta” which is a Japanese mini shop
https://m.facebook.c...mibextid=ykz3hl
Mini delta website
https://delta-mini.c...ーボールジョイント&ロックタ/
Edited by timmy850, 27 January 2023 - 08:47 PM.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 27 January 2023 - 08:23 PM
Minispares Have stated they are different joints to the ones Guessworks sell.  I wonder how long roughly they last compared to standard ones?
#5 mab01uk
mab01uk
  • 12,538 posts
Posted 27 January 2023 - 10:51 PM
Also available a bit cheaper for 4-off
MAINTENANCE FREE BALL JOINTS - (CAR SET of 4) C-GSJ166KIT
£224.64 inc vat.
http://www.minispare...MS.aspx|Back to
#6 IntMilkBrilliant
IntMilkBrilliant
  • 15 posts
Posted 28 January 2023 - 08:07 AM
Shooter
They are not the same...
#7 Shooter63
Shooter63
  • 1,079 posts
Posted 28 January 2023 - 10:36 AM
Shooter
What's the difference then?
Shooter
#8 mini13
mini13
  • 3,811 posts
sadly it's a probably case of supply and demand, if they could sell loads then the price would come down, but it's a limited market.
it's more more cost effective in the long run to go down the kad alloy hub route,
#9 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 28 January 2023 - 11:04 AM
Shooter
Shooter
They are made by different companies
From David Ainley at CMJ
“ Another local write up about the maintenance free ball joints here in Japan over the weekend.
Unlike the copies that are floating around the UK at the minute, the original was in testing for over 3yrs and is continuously being checked for improvements and weak points.
Requires greasing on initial installation.
http://classicminisj...all-joint-kit/”
#10 ac427
ac427
  • 679 posts
Posted 28 January 2023 - 04:20 PM
So the CMJ ones are different from the MS ones?
Are the Mini Delta ones different the CMJ supplied ones?
Edited by ac427, 28 January 2023 - 04:21 PM.
#11 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 28 January 2023 - 07:33 PM
CMJ = Minispares = Mini Delta
Bottle top is a different supplier
#12 Alex_B
Alex_B
  • 4,573 posts
Posted 28 January 2023 - 10:38 PM
I am also curious as to the differences between the CMJ / Delta Mini ball joints vs Guessworks ones. I have fitted a few sets of Guessworks joints now and have been very impressed with the quality but have seen some differences of opinion posted online, unsure on how much should be read into that however.
But overall I definitely see the benefits of the fit & forget joints, it's hard to justify the cost of fitting standard type joints when factoring labour costs / time involved in lapping them in compared with how much quicker it is to fit the sealed items. On customer cars it's a no brainer in my opinion, glad to see them becoming more available over here now!
#13 ac427
ac427
  • 679 posts
Posted 30 January 2023 - 01:09 AM
I didn't realise there was any lapping in to be done. I thought they just fitted in the suspension arm as long as the hole in the arm was clear?
#14 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 30 January 2023 - 02:20 AM
The stock ones will often have a few high points and it can be worth lapping them in before attempting to shim them. This will also mean there’s a bit longer before they need to be shimmed again as they won’t wear quicker at the start
The sealed ones are pretty much bolt on and go
In terms of workshop labour as he mentions, bolting on a 4 sealed units might take 5 minutes, but shimming the stock ones correctly might take an hour or so. The labour cost might outweigh the additional part cost
#15 sonscar
sonscar
  • 3,047 posts
Posted 30 January 2023 - 11:29 AM
Four standard for £40,four updated for £200+.My time is free(retired)so no brained for standard ones.Paying labour?close choice.Steve..
