Mini Spi With Rover 214 Si Compatibility
22 replies to this topic
#16 genpop
genpop
  • 509 posts
Posted 10 August 2023 - 06:34 PM
Yes, this way you see if the lambda heater works too!
#17 genpop
genpop
  • 509 posts
Posted 13 August 2023 - 08:28 PM
Hi,
i had a second look to your logfile.It seems as if you have a short connection in your lambda wiring.When you have a look to lambda status .The row is repeatedly broken after a few seconds .
Have a look in excel.As a second action i would degrease the longtermfueltrim. This is possible with most of the known diagnose tools.
#18 dimmad83
dimmad83
  • 12 posts
Posted 22 September 2023 - 12:24 PM
Update for the idle issue.
After removing the 1.5 rocker arms, the car is running like a charm.
All issues fixed.
#19 genpop
genpop
  • 509 posts
Posted 22 September 2023 - 04:30 PM
Will you attach a .txt file please.
#20 dimmad83
dimmad83
  • 12 posts
Posted 25 September 2023 - 06:03 PM
RTF is like txt
  • Attached File  Spi.rtf   938.04K   5 downloads
#21 genpop
genpop
  • 509 posts
Posted 26 September 2023 - 08:24 PM
Hi dimmad83,
it was hard work to change your file into a readable one. csv or txt would have been easier.
But i m sorry to say something is still wrong. According to your log lambda status is still fluctuating  " 111110111011111" and so on.Maybe therefore lambdastatus is zero all the time and shorttimefueltrim nearly steady. I would have the ecu checked, there are some companies in GB which do that.
Or somebody else has an explanation for this behaviour.
#22 dimmad83
dimmad83
  • 12 posts
Posted 28 September 2023 - 12:35 PM
Hi dimmad83,
Sorry mate, it was not on intentional, just the Macs have another opinion about txt files.
The file also contains the calibration period of the steper motor.
And a 30-min drive from the shop to my garage.
Now idle is perfectly fine, all numbers are green.
The only scenario of lambda out of range is when I lift the throttle with RPMs and a gear selected then zeroes itself.
Vacuum is ok
There is a small delay to understand that the throttle is slightly touched and instead of open throttle shows idle even though is rolling.
#23 genpop
genpop
  • 509 posts
Posted 28 September 2023 - 06:47 PM
Edited by genpop, 28 September 2023 - 06:52 PM.
