Engine Runs But Only With Clutch In...?!
35 replies to this topic
#1 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 18 April 2023 - 01:13 PM
Long story short, engine starts and runs fine but ONLY with the clutch pedal fully depressed/in. Bringing the clutch out to apply a gear, it stalls the engine. It will not start with the clutch pedal out/untouched.
Car is definitely in neutral, as it does not lurch forward when trying to start.
What I know:
- starter. Strong and gives a solid clunk when trying to start (plus it starts the car with the clutch in fine)
- battery. Great crank voltage tested
- removed wok and release bearing to remove these from the potential issue list. Car will not start with wok off.
Before I rip the engine and box out, does anyone have any suggestions? I've had a look online and can't find any information on this issue.
Edited by Mini 360, 18 April 2023 - 01:14 PM.
#2 nicklouse
  • 18,003 posts
Posted 18 April 2023 - 01:48 PM
Sounds like you have some long bolts catching the flywheel?
#3 Mini 360
Mini 360
  • 4,933 posts
Posted 18 April 2023 - 01:58 PM
Where about? Surely engaging the clutch wouldn't magically shorten bolts?
#4 nicklouse
  • 18,003 posts
Posted 18 April 2023 - 02:13 PM
No but it moves the flywheel away from quite a few.
is it making bad noises as you lift the clutch pedal as it stops?
bolts that can cause problems. Engine mount. Clutch slave (bracket) the old starter solenoid mount.
#5 Mini 360
Mini 360
  • 4,933 posts
Posted 18 April 2023 - 03:07 PM
No bad noises. Here's a video of the engine cutting out as I release the clutch.
https://youtu.be/Vq0Q3KtQ8Mc
Edited by Mini 360, 18 April 2023 - 03:07 PM.
#6 Mini 360
Mini 360
  • 4,933 posts
Posted 18 April 2023 - 03:17 PM
All bolts you mention are all as they have been since I've owned the car and previously ran ok.
#7 GraemeC
GraemeC
  • 7,336 posts
Posted 18 April 2023 - 04:18 PM
What is the car/engine?  Carb, SPI or MPi?
Has anything been done to the engine recently or has this just started happening out of the blue?
Edited by GraemeC, 18 April 2023 - 04:20 PM.
#8 Mini 360
Mini 360
  • 4,933 posts
Posted 18 April 2023 - 04:20 PM
1275cc Carb. Engine came out to fix an oil leak on the diff housing.
Edited by Mini 360, 18 April 2023 - 04:20 PM.
#9 KTS
KTS
  • 2,310 posts
Posted 18 April 2023 - 04:27 PM
very odd - it's like the primary gear wont turn
take the plugs out, put it in 4th gear and push it.  does it roll ?
#10 GraemeC
GraemeC
  • 7,336 posts
Posted 18 April 2023 - 04:29 PM
When you say it won't start with the clutch out, what does it do?  Does it turn over and not fire or does it do nothing at all?
#11 GraemeC
GraemeC
  • 7,336 posts
Posted 18 April 2023 - 04:30 PM
I was thinking seized primary too, but that wouldn't cause a perceivable issue in neutral (if it is actually in neutral)
#12 KTS
KTS
  • 2,310 posts
Posted 18 April 2023 - 04:57 PM
seized primary usually behaves like you can't disengage the clutch.
in this case the clutch appears to be working, but as it's released and starts clamping the clutch plate the engine stalls, suggesting the clutch plate itself cannot rotate for some reason
the primary is free on the crank tail as the engine runs with the clutch in, so i think the issue must be downstream somewhere
Edited by KTS, 18 April 2023 - 04:58 PM.
#13 imack
imack
  • 1,885 posts
Posted 18 April 2023 - 05:04 PM
Two gears selected?
You've had the diff housing off, I presume it's a rod change box. Never worked on rod change myself but I'm guessing you have to mess with the selector mechanism when removing the diff case.
#14 Spider
  • 14,006 posts
Posted 18 April 2023 - 06:12 PM
Something in the Gearbox is locked up.
#15 Gaz66
Gaz66
  • 637 posts
Posted 18 April 2023 - 07:43 PM
Put it in first gear and let the clutch up..does it set off? If not and just stalls you may have it locked in two gears.
This is quite possible after having the diff casing off and the selector rod/detent spring and plunger is messed up.
