Engine Runs But Only With Clutch In...?!
35 replies to this topic
#31 Gaz66
Gaz66
  • 745 posts
Posted 04 May 2023 - 06:30 PM
Is the side casing toast as well?
#32 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 04 May 2023 - 08:03 PM
Thankfully not! The bearing race has thankfully taken the brunt of it.
#33 Mini 360
Mini 360
  • 4,933 posts
Posted 20 May 2023 - 05:03 PM
The plot thickens.....
With the damaged race and bearing replaced, I reassembled the drop gear housing along with the clutch and flywheel. Guess what? Same issue, engine locked up completely and wouldn't turn by hand. Take the clutch and flywheel assembly off and spins fine.
Fearing it's more gearbox related, I've just removed the box from the engine to see if there's anything amiss. I've shot the below video for reference. All gears spin and engage perfectly, with no issues at all. There is no damage to any gears in the box or drop gears.
As such, I'm completely stumped as to why this is still happening.
https://youtu.be/GGf5Rf29aC8
Any thoughts?
Edited by Mini 360, 20 May 2023 - 05:54 PM.
#34 KTS
KTS
  • 2,382 posts
Posted 20 May 2023 - 05:08 PM
with the engine and transfer case refitted, does the primary gear spin freely on the crankshaft ?
#35 Mini 360
Mini 360
  • 4,933 posts
Posted 20 May 2023 - 05:13 PM
Yes it does. Only issue is when the clutch and flywheel assembly is installed and torqued to spec.
#36 KTS
KTS
  • 2,382 posts
Posted 20 May 2023 - 09:38 PM
If the flywheel locks solid when fitted it's most likely because its jamming on something in the transfer housing (check for protruding bolts).
