1968 Mini Cooper S
45 replies to this topic
#1 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 13 July 2023 - 06:24 PM
I have been looking for a Cooper S for a while now and finally found one that ticks all the boxes.
Its a 1968 Cooper S Mk2 which bodywise appears to be in very good condition having had some restoration work carried out at various stages in its life.
There are a number of points which require attention that I am hoping to carry out as running repairs.
There are lots of smaller tasks to carry out, no horn, no door mirrors, sliding windows don't lock, wipers dont give a full sweep, stiff gearchange to name a few but the priority is to give it a good service and tune and to sort out the brakes.
Here's a poor quality photo, I will add more as things progress.
#2 floormanager
floormanager
  • 696 posts
  • Local Club: Mini Club Sussex
Posted 13 July 2023 - 08:38 PM
Congratulations and welcome to the club!
#3 wingnut
wingnut
  • 463 posts
Posted 14 July 2023 - 04:18 PM
Well done for finding one and I look forward to the updates.Have you rung Ben at Mill Road yet to tell him his got some more work coming his way
#4 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 14 July 2023 - 05:30 PM
Funny you should mention that, I am visiting the Isle of Wight in a week or so's time, so I will drop in and see him and make enquiries of when he has some time to fit the new Mini in.
I have been working through some of the minor problems but it seems to be one step forward and then 2 back.
On checking why the handbrake was so poor I have discovered that it needs new drums as the original ones are scored but there currently out of stock at Minispares so that will have to wait, I then thought I would check why the window locks weren't working, the locks had been fitted back to front and without gaskets so a new set will be ordered. I then moved on to the wipers but can't work out why they dont give a full sweep?
#5 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 20 July 2023 - 05:25 PM
Sorted the Horn problem by replacing this
Fitted some door mirrors
I tried fitting new spacered drums to the rear brakes but found that the spacered drums currently fitted are about 10mm less than the replacement, anyone had similar problems?
#6 Homersimpson
Homersimpson
  • 829 posts
Posted 20 July 2023 - 05:43 PM
I always thought that all spacered drums were the same?  The ones you have are not metro rear ones are they?
#7 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 20 July 2023 - 06:03 PM
I have just looked at Metro drum height sizes, they are 60, 83, 89, and 91mm. The spaced drums I have purchased are 83mm and the ones on the car are 70mm.
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 21 July 2023 - 02:57 PM
GDB105 - Standard
21A1457 - 1/4" built in spacer
GDB106 - 3/4" built in spacer
If you are running 7" Cooper discs then the 21A1457 is the correct rear drum.
If you are running 7.5" Cooper S discs then GDB106.  Obviously this will add 1/2" to the rear track each side over what you have now, so the wheels may then stick out.
Edited by GraemeC, 21 July 2023 - 03:00 PM.
#9 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 21 July 2023 - 03:17 PM
Thanks Graeme, that explains things clearly.
I have purchased a pair of the GDB 106 drums but in order to fit them I would need longer wheel studs and with the 165 tyres I have it would require arches to be fitted.
It would appear that the 21A1457 is no longer available so I may need to get standard drums and fit a 10mm spacer.
Edited by JXC Mini GT, 21 July 2023 - 03:18 PM.
#10 GraemeC
GraemeC
  • 7,438 posts
Posted 21 July 2023 - 03:27 PM
That drum was Cooper fitment, not Cooper S so I assume someone has changed them at some time to accommodate a change in wheel without needing arches.
I think there are both 5mm and 9.5mm spacers available - I'm sure one of those would suit perfectly
#11 GT Jimmy
GT Jimmy
  • 1,644 posts
  • Local Club: S.U.N.M.C
Posted 24 July 2023 - 07:32 PM
Looks a good mini, will you be keeping the GT and running both?
#12 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 25 July 2023 - 07:29 AM
Intention is to keep both, the GT is my favourite and will continue to be used regularly.
The S will be used less frequently, if I can sort out some minor problems I am hoping to take it on the IOW mini run in September.
#13 Steve220
Steve220
  • 5,047 posts
  • Local Club: BMC
Posted 25 July 2023 - 07:39 AM
Nice find!
#14 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 01 August 2023 - 01:57 PM
My brake drum problems continue, I purchased 9.5mm spacer with standard drums
After fitting the tyre has about 1mm clearance from the shock absorber, I have spoken to Minispares who have suggested using a 3mm wheel spacer shim, hopefully that will solve the problem.
Also while flushing the cooling sytem through I noticed the cylinder head bolt moving, on checking, the bolt has sheared off, so my next job is to remove the cylinder head to replace the bolt, would it be prudent to replace the existing cylinder head studs with new ?
#15 JXC Mini GT
JXC Mini GT
  • 845 posts
Posted 04 August 2023 - 05:32 PM
Took the cylinder head off today to remove the remains of the broken bolt.
I believe the engine has only covered about 1500 miles since being rebuilt, and the conditon of No 4 piston confirms that.
I am also going to replace all hoses, water pump, thermostat and temp sensor after discovering this when I removed the radiator.
