7 Port Fuel Injection
64 replies to this topic
#31 IronmanG
IronmanG
  • 1,249 posts
  • Local Club: Box hill. Lsmoc member
Posted 17 August 2023 - 01:06 PM
What rockers are you running
#32 IronmanG
IronmanG
  • 1,249 posts
Posted 17 August 2023 - 01:10 PM
With print out this time
Nothing wrong with that. Just needs the limit reset and probably another couple of hours on the RR just to sweeten it up. Don't expect anymore torque out if it
Edited by IronmanG, 17 August 2023 - 02:31 PM.
#33 Steve220
Steve220
  • 5,064 posts
  • Local Club: BMC
Posted 17 August 2023 - 02:24 PM
It seems the moral to this story is by all means put on a 7 port head but put carbs on it too 👍
If set up properly, efi far surpasses carbs on this application. Problem is when the ecu and advice given by the manufacturer is garbage.
#34 IronmanG
IronmanG
  • 1,249 posts
Posted 17 August 2023 - 02:28 PM
Yep
#35 IronmanG
IronmanG
  • 1,249 posts
Posted 17 August 2023 - 02:29 PM
Will get some CR6E plugs and try them, I also have some NGK CR7EIX 7385 iridium that I can try.
i spoke with Kieth about the cam and got it directly from him with matching cam followers
I built the engine myself.
Engine build is capability of circa. 100bhp at 7500rpm but as I’m running on the road I set the limiter to 5200rpm, I’m not chasing max power.
will look at fitting a lambda sensor
will look to see if there is a Delta specialist in my area
Think you've answered it there, rev limit way too low, 266 is very mild on a 5 porter never mind a 7 port.
Run 7 plugs for years on my hot 5 porter 1380, tried 8's the last few weeks, work fine on the road.
Weren't you running the vintage mini set up with bike carbs?
#36 PoolGuy
PoolGuy
  • 855 posts
Posted 17 August 2023 - 08:18 PM
When will the engine be ready to go?
It's unlikely to be this year, the block is currently having liners fitted.
#37 IronmanG
IronmanG
  • 1,249 posts
Posted 17 August 2023 - 08:21 PM
Which throttle bodies?
#38 PoolGuy
PoolGuy
  • 855 posts
Posted 17 August 2023 - 08:35 PM
Jenveys, and the Polestar ECU.
#39 IronmanG
IronmanG
  • 1,249 posts
Posted 17 August 2023 - 09:31 PM
Interesting stuff chaps, keep it up. Interestingly my (cast) head was supplied with C7 plugs, but I’ll be using 6’s for first start and initial running. Also it was supplied without injectors and I was recommended 180’s, 1275, SW8, 10.5:1. Time will tell how it goes, not using the SC ecu.
Is the sw8 your choice? I mean was it suggested to you by the supplier
Edited by IronmanG, 17 August 2023 - 09:32 PM.
#40 Java_Green
Java_Green
  • 172 posts
Posted 18 August 2023 - 08:30 AM
What valve sizes do you use?
Why should not anymore torque be expected? From what I have read, at several different places, the 5 port head is choked already at farely low rpm´s. Based on that, I would expect the 7 port head to be superial even at 5200rpm.
#41 Dominic Dent
Dominic Dent
    Just On Tickover
  • 8 posts
Posted 18 August 2023 - 11:06 AM
Running MED 1.3 rockers
Edited by Dominic Dent, 18 August 2023 - 11:06 AM.
#42 PoolGuy
PoolGuy
  • 855 posts
Posted 18 August 2023 - 11:51 AM
It’s my choice, reason being, it’s used everyday so I want a usable spread of power, it’s only 1275 so a SW10 would probably be too much. However, it’s the only part that I haven’t bought yet, so I’m following this discussion with interest.
#43 IronmanG
IronmanG
  • 1,249 posts
Posted 18 August 2023 - 12:02 PM
It's the port sizes. They are oversized so air speed through the head is slower than a 5 port. With the cast head 90 ft/lbs ish seems to be about the limit where a decent 5 port can go past that. We are talking numbers on a dyno. As Cooperman often says,you probably wouldn't feel it on the road only see it round a racetrack.
It comes down to bang for your buck. If you buy the head and throttle bodies for say 3k or whatever it is,is that worth it over a fully worked 5 port head that cost 900 quid. No. Not for a tiny amount of increased performance over 6000 rpm
Edited by IronmanG, 18 August 2023 - 12:03 PM.
#44 IronmanG
IronmanG
  • 1,249 posts
Posted 18 August 2023 - 12:05 PM
It's the first question I always ask is which camshaft.
#45 Java_Green
Java_Green
  • 172 posts
Posted 18 August 2023 - 01:01 PM
So, what are the valve sizes you use/recommend (I am referering to the Pierce casted head) ?
