4 Pot Calipers
20 replies to this topic
#16 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 05 September 2023 - 04:43 PM
Don't think you would see big brakes under the cooper s rims.
#17 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 05 September 2023 - 05:07 PM
My opinion, 4 pots are better back to back than S calipers, same disc, pad compound.
As used on the last works Minis.
#18 ac427
ac427
  • 733 posts
Posted 06 September 2023 - 10:38 AM
with an 8.3" disk you can get 10" split rims on with Kad 6 pots,
under the original S rims you are severely limited,  basically, its either S calipers, or a fiesta conversion as the only viable options, I seem to remember mention of the Specialist components 4 pots fitting some wheel's but cant find any details on them now, but I'd be suprised if they went under S rims
I hadn't heard of that, which type of split rims are you referring to?
I thought the KAD 7.9" disc was the largest you could go with 10" wheels?
Edited by ac427, 06 September 2023 - 10:38 AM.
#19 mini13
mini13
  • 3,811 posts
Posted 06 September 2023 - 11:14 AM
generally most split rims i belive, spectrum/ force etc.
i think 7.9" is the biggest you can go with a 4 pot setup,
the Kad 6 pots are radial mount, so you can mount them so they just clear, then turn the discs to the correct size, IIRC at 8.3 " you dont even have room for stick on wheel weights... so not suited for the road, bu then the 6 pots dont have seals anyway... so not really suited for the road...
Edited by mini13, 06 September 2023 - 11:17 AM.
#20 ac427
ac427
  • 733 posts
Posted 06 September 2023 - 01:16 PM
KAD did have a template on their website you could print out and check with your wheels for clearance.
True, It's shame they don't keep a list of what fits and what doesn't though. Perhaps it is down to liability.
#21 ac427
ac427
  • 733 posts
Posted 06 September 2023 - 01:19 PM
Thanks, i had been looking at those 7.9" setups. They are expensive but nice and shiny like all KAD parts. I already have the original cast KAD calipers with 7.5" discs. But damn those 7.9" look nice :D
