Rear Subframe Support Pin And Flat Washer
Best Answer KevinS , 27 November 2023 - 02:29 PM
Hi nicklouse, I've been confused too.
However after further investigation, I believe I know the answer to the problem I posted. If you take a look at the minispares parts diagram that shows PWZ207 and the Subframe Support Pin, it shows a PWZ207 washer to be fitted on the end of the Subframe Support Pin. This is incorrect. In addition and detailed within the same diagram, it also shows the large single trunion bush being installed in a way so that the large end rests against the head of the Support pin when in fact it should be located the other way round, wide part of Bush to subframe.
I cannot take credit but thanks to Josh Willis at JW Mini Services in Ashford for pointing out the errors I was making.
Regards
Go to the full post#1
Posted 27 November 2023 - 06:52 AM
Many thanks.
Posted 27 November 2023 - 01:04 PM
I am lost on which end of the subframe you are working on.
The only big washer is the one on the back.
But there is no pin to slide about as it is part of the subframe. No big washer on the front.
pics of your problem would help us understand what you are doing.
Posted 27 November 2023 - 02:29 PM Best Answer
Regards
Posted 27 November 2023 - 02:56 PM
Never use a part diagram as fitting info. Use a workshop manual.
Posted 27 November 2023 - 03:41 PM
do you mean the front one or the rear one
no 9 at the bottom, is that the bit you're referring to (is that front bush in 2 parts ? I'll have to have another look now actually I thought it was one piece pressed in, pretty sure there would be a lip on both sides otherwise not held in firmly..)
the washer goes on the inside face of the subframe before the nut
back end diagram looks fine ?
(edited a few times due to working from memory ..)
it also looks like It's pointing the pin towards the hole where the radius arm pivot comes out which is a bit misleading
Edited by stuart bowes, 27 November 2023 - 04:12 PM.
Posted 27 November 2023 - 04:21 PM
Hi, errors are in the front drawing. Have been told that part 9 is GFK1116 and not PWZ207 as stated. Front part can be 1 piece in rubber or 2 piece poly. I've elected for a 1 piece in rubber. Yes I agree, front drawing is misleading.
Posted 27 November 2023 - 04:28 PM
Edited by stuart bowes, 27 November 2023 - 06:56 PM.
Posted 27 November 2023 - 06:42 PM
Posted 27 November 2023 - 06:55 PM
Outside edge having the lip definitely makes more sense to me as well (and looking at my parts the head of the large pin isn't really big enough to act as a washer I.e not sufficiently larger than the hole in the bracket) so I would agree
Unless anyone can give us a decent reason why that's wrong
Edited post above to remove misleading info
Edited by stuart bowes, 27 November 2023 - 07:06 PM.
Posted 27 November 2023 - 07:17 PM
Posted 28 November 2023 - 06:30 AM
Examples of how the large single Bush was fitted at the factory.
Posted 28 November 2023 - 07:07 AM
Posted 28 November 2023 - 10:08 AM
I'm going back and forth on this one now... see now I'm thinking with the wider part outboard, the frame can in theory move left to right slightly (although unlikely in reality due to boot floor fixings but still..)
whereas with the wider part sandwiched in between frame and bracket, the frame is snugly held in between the two points. I suppose it's easy enough to slightly trim one edge so it fits more neatly?
I would be a lot happier if it was a 2 part bush, like the rear ones, then you get a lip both sides
Edited by stuart bowes, 28 November 2023 - 10:10 AM.
Posted 28 November 2023 - 08:02 PM
The way Rover fit them in the workshop manual. Also Note number 3 standard plain washer no big washer.
Edited by nicklouse, 28 November 2023 - 08:12 PM.
Posted 28 November 2023 - 08:13 PM
Then just use the old setup as that used the rear setup at the front.
