Over the last 1/2 years I've been doing various work on my Mini, including having the engine out, stripped, cleaned and rebuilt. I had the block bored +60, ported head and fast road cam fitted but no other work done, gear box was cleaned but not stripped, and a new clutch was fitted.
I've put the engine back in the mini and had it running (only to check I got everything correct) so it hasn't done and driving since.
My problem is with the clutch (verto) - when put into gear i get no bite at all. I've gone through all the components from pedal up to the slave cylinder and replaced them all - clevis pins, master cylinder, braided hose, slave cylinder, I've pressure bled it and no air in the system but still no bite.
I'm a bit lost with what to do next. Since all the 'external' components are new and working, my assumption is that it could be an 'internal' issue (i.e. inside the clutch cover plate) and I'm really hesitant to do this as 1. I have no experience in this and 2. I've just paid to have all the work done on the engine and rebuilt...
Can anyone advise what I should check and what my next steps would be if I have to remove the clutch cover and check internally? I've attached somer photos and video of the cslave cylinder in action.
