To me something doesn't look right with the groove in the end of the the crank. Top left groove's bottom edge in the above photo looks very worn, and what looks line fine metal swarf around it and on the front of the pressure plate. Not that that should have any effect I am sure on the clutch's operation unless the flywheel keyway locating plate is not fitted correctly to match up with the offset on the crank. This might explain the ware in the keyway. IF one side is almost fitted into the slot and the flywheel bolt is torqued up to the correct setting the other side of the key plate could before forced into the slot but not all the way as the extra pressure means the nut has reached it's correct torque before the whole unit is sitting as far onto the crank as it should be.
Just my thoughts.
Paddy
Edited by Designer, 12 February 2024 - 08:08 AM.
