Should I Be Able To Read The Ohms Of This Coil With This Multimeter?
22 replies to this topic
#1 jiminwatford
jiminwatford
  • 291 posts
Posted 26 February 2024 - 06:00 PM
Following what AC Dodd says in this video https://youtu.be/Vnv...MCSqpzWQmiHC1V4 i wanted to test the ohm reading on my coil So i bought a multimeter from Screwfix and can't get a reading
Attached File  IMG_20240226_175412_108.jpg   23.85K   8 downloads
There is an ohm symbol there but no reading shows
I'm either doing it wrong or the multimeter is not right for it
#2 sonscar
sonscar
  • 2,727 posts
Posted 26 February 2024 - 06:07 PM
Set to ohms and touch the leads together and you should get zero.The display lights up?Steve..
#3 jiminwatford
jiminwatford
  • 291 posts
Posted 26 February 2024 - 06:17 PM
Yes i get a zero reading when doing that
Attached File  IMG_20240226_181433_327.jpg   37.47K   3 downloads
#4 bpirie1000
bpirie1000
  • 2,119 posts
  • Local Club: Amoc
Posted 26 February 2024 - 06:45 PM
Have you still got the instructions for the multimetre?
#5 jiminwatford
jiminwatford
  • 291 posts
Posted 26 February 2024 - 06:47 PM
Yes but i don't know what i'm looking at / for. I've never used a multimeter before and am very unfamiliar with them
#6 stuart bowes
stuart bowes
  • 1,591 posts
Posted 26 February 2024 - 08:00 PM
presumably if you get any bit of random cable, the longer the better, you'll get some sort of reading measuring between both ends
far as I'm aware there should be nothing more complicated to it than putting one probe at each end and numbers come up .
though I'm not a qualified sparkie I have used them numerous times.  mostly I get ohms readings when I forget to switch mine over to the continuity setting - the next setting along like the wifi symbol, should buzz when you touch them together (which you should be able to use to check your leads aren't duff)
Edited by stuart bowes, 26 February 2024 - 08:03 PM.
#7 jiminwatford
jiminwatford
  • 291 posts
Posted 26 February 2024 - 09:29 PM
I'm wondering if this multimeter is right for the job
Attached File  IMG_20240226_211551_881.jpg   44.49K   2 downloads
the coil should read 0.8 ohms and i don't think the multimeter goes down that far?
When i put the positive lead into the centre of the coil (and the black to the negative) it reads 10.06 and there is always a little 'K' on the screen. So that's 10 thousand ohms?
I can't seem to get rid of the 'K' so it just reads them singly rather than in thousands
#8 jiminwatford
jiminwatford
  • 291 posts
Posted 26 February 2024 - 09:36 PM
My conclusion is it won't read low enough. So i have ordered one of these https://www.ebay.co....mCondition=1000
'Measuring Resistance Range: 0~99.99MΩ'
#9 Spider
  • 13,937 posts
Posted 26 February 2024 - 11:12 PM
When measuring Coils, they are in a way, similar to Capacitors, they take time to charge and settle down to a stable reading of the actual DC Ohmic resistance of the coil. Connect it up and depending on the meter, you might need to leave it as long as a minute to get a proper reading.
#10 Steam
Steam
  • 545 posts
  • Local Club: Victorian Mini Club
Posted 27 February 2024 - 01:59 AM
You really need a range of 200 Ohm to check low resistance.
#11 jiminwatford
jiminwatford
  • 291 posts
Posted 27 February 2024 - 08:35 AM
The one i have ordered has a Measuring Resistance Range: 0~99.99MΩ
I think it has a 200 ohm section?
Attached File  s-l1600.jpg   62.59K   3 downloads
#12 Lplus
Lplus
  • 557 posts
Posted 27 February 2024 - 09:30 AM
yes, at 6 o'clock
#13 sonscar
sonscar
  • 2,727 posts
Posted 27 February 2024 - 09:57 AM
It obviously can go down that far as it is possible to read zero with it.from pos to neg should be a few ohms and from center to neg should be thousands( I think)Steve..
#14 stuart bowes
stuart bowes
  • 1,591 posts
Posted 27 February 2024 - 10:26 AM
seems to me the original one should have been fine on the 2kohm setting, if it has a resolution of 0.001 - using the available 4 digits in that position your 0.8 ohms would read 0.800
in the 20kohm setting it would read 00.80
in the 200kohm setting it would read 000.8
that's not to say the meter itself isn't duff or poorly calibrated of course
did you confirm the leads were ok using the continuity test
bit moot now I suppose if you already ordered new
Edited by stuart bowes, 27 February 2024 - 10:26 AM.
#15 jiminwatford
jiminwatford
  • 291 posts
Posted 27 February 2024 - 11:55 AM
I don't know if it allows me to manually adjust the settings. I think it measures the resistance and decides which setting to display it in. On the coil it shows 0.001. When touching just the leads together it shows 0.000
