No. It would actually "do the job" but it isn't what I'm looking for.
What I want is an ignition system with no electronics on the engine. Points work fine as points or to trigger my external modules, I just would like something even more reliable. The Lucas CEI setup would be ideal, I only need the distributor. The CEI setup had a reluctor setup in the distributor which is basically coils and magnets - no electronics. That then connected to an external box which actually just had a GM HEI module inside. Most electronic distributors worked this way, even if the module was bolted to the distributor.
There are two ignition systems I am building. one is a CB performance black box which allows for advance configuration etc. The other one is based on a GM HEI module. The GM modules get installed on absolutely anything due to the price and reliability, that includes mowers and even Fords
. Both of these can be triggered by points and will last a very long time but a reluctor setup will last even longer.
Edited by 68+86auto, 13 March 2024 - 11:22 AM.
