Magnetic Trigger Distributor To Suit Mini
28 replies to this topic
#16 Steam
Steam
  • 821 posts
  • Local Club: Victorian Mini Club
Posted 14 March 2024 - 05:13 AM
I was thinking that surely at some stage someone made an aftermarket HEI setup to fit Lucas distributors.
Another possible option is a Scorcher Distributor - been ages since I dealt with them. They are based in Melbourne and make distributors for A and A+ Series (and many other engines) based on Bosch Dissy's.
Performance Ignition Systems is the company;-
https://performancei...m.au/p/scorcher
Lucas made an electronic module that was stand alone and you bought the pickup and trigger wheel to suit you car. I will have to look up the name but I doubt they would be available second hand anyway
#17 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 14 March 2024 - 08:01 AM
That’s right, there’s one now sold as the “Lumenition Optronic” which have a fitting kit for each distributor and then a master ignition system. It uses an optic sensor though
https://www.merlinmo...g-kit-lum-fk117
https://www.merlinmo...-kit-lum-cek150
Instructions:
https://www.merlinmo...nstallation.pdf
There is also a system called “magnetronic” by Lumenition
https://au.gsparkplu...4-ve-earth.html
Edited by timmy850, 14 March 2024 - 08:22 AM.
#18 Steam
Steam
  • 821 posts
Posted 14 March 2024 - 09:01 AM
Lumenition is not Lucas. The Lucas 9ne was just labeled as 'Lucas ignition amplifier' but I think it also had an optic sensor or a hall eff3ct now I think about it. Before that was the Lucas TAC.
#19 68+86auto
68+86auto
  • 1,011 posts
  • Local Club: Queensland Mini Car Club
Posted 14 March 2024 - 10:03 AM
This is possibly the one you were thinking of, the AB13.
Attached File  Screenshot_20240314_194319_eBay~2.jpg   40.21K   0 downloads
I don't know what it was like, seems like it may be an earlier version to the AB14 (CEI) which is the one that uses the GM module. If it was a magnetic trigger then that is what I need.
I also found there was the TAC.
They also had the OPUS system but they replaced OPUS with CEI due to the OPUS being unreliable.
Edited by 68+86auto, 14 March 2024 - 10:06 AM.
#20 68+86auto
68+86auto
  • 1,011 posts
Posted 14 March 2024 - 10:13 AM
It looks like the AB13 was a hall effect system. Magnetic would only have two wires from the distributor.
I often find useful information just by looking on eBay. That's where I got these pictures.Attached File  Screenshot_20240314_200843_eBay.jpg   33.45K   1 downloadsAttached File  Screenshot_20240314_200847_eBay.jpg   48.71K   1 downloadsAttached File  Screenshot_20240314_200850_eBay.jpg   34.05K   1 downloads
#21 nicklouse
  • 18,696 posts
Posted 14 March 2024 - 12:56 PM
Guess what I have in my garage.
And the correct dizzy. A series though.
#22 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 14 March 2024 - 02:16 PM
Trust you have ruled out the likes of megapolis type or edis.
#23 Ethel
  • 26,073 posts
Posted 14 March 2024 - 03:04 PM
The 59DM4, as shown in Timmy's photo was most commonly found on Austin Maestros. Pretty sure the only Metro to use it was the Turbo.
It'd been superseded by the 65 by the time electronic ignition was standard on Metros and Minis.
#24 68+86auto
68+86auto
  • 1,011 posts
Posted 14 March 2024 - 11:50 PM
For now...
Maybe in the future. I assume you mean megajolt.
I'd like to keep the system relatively simple and cheap.
#25 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 15 March 2024 - 09:48 AM
For now...
Drammed autocorrect...
I would say keep an eye out at autojumbles. Mega jolt getting hard to find these days never mind an old escort or sierra..
#26 Ethel
  • 26,073 posts
Posted 15 March 2024 - 12:06 PM
Sparkduino with coil on plug, or an amplified coilpack, is the new MJ
#27 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 22 March 2024 - 12:12 AM
I wonder if this is worth a shot
#28 68+86auto
68+86auto
  • 1,011 posts
Posted 22 March 2024 - 01:10 AM
That one is designed to work with a DIS, the reluctor is in the rotor position.
I was thinking of making something though. I found some NOS Mitsubishi reluctors and pickups on eBay. I just don't know what direction they were designed for, I think it might matter. https://www.ebay.com...tm/166129864035 I just don't know if the reluctor would fit over the cam and then I'd need a way to secure it. That's just one of the cheapest ways I can find to get a pickup and reluctor. There are plenty of others but they are more expensive and have the same fitment question.
#29 68+86auto
68+86auto
  • 1,011 posts
Posted 13 April 2024 - 07:02 AM
There are some minispares/truespark distributors that use a reluctor/magnetic trigger however the module is still inside the distributor. If the pick-up was separate to the module I could make it work.
Attached File  image-1.jpeg   48.3K   0 downloads
    Bing (1)
