All you need is for the Oil Light to go out before you start it that first time.
Oil Pressure Problem
TheRedBullet
, Mar 24 2024 07:10 PM
18 replies to this topic
#16
Posted 25 March 2024 - 07:56 AM
#17
Posted 25 March 2024 - 11:53 AM
crank over without plugs in and you should see oil at the rocker shaft then you know it is primed before starting after rebuild
#18
Posted 25 March 2024 - 12:08 PM
Okay I tried priming the pump and used the switch only and the orange oil light fades out when cranking, now I will attempt to start it and hope for the gauge to start reading pressure as its not moving a bit when cranking only with the gauge connected.
#19
Posted 25 March 2024 - 04:50 PM
Problem solved, After connecting a booster to my battery and changing the kinked oil gauge pipe I managed to get 80 psi and no orange oil light on the dash. thank you guys for helping me.
