Lada 2103
99 replies to this topic
#91 panky
panky
  • 1,850 posts
Posted 14 June 2026 - 09:51 AM
I used to work at BOC on the West Bank Dock estate and quite often heard, and saw, 6R4s and others tearing up the tarmac and drifting around the roundabout on test from RED :mrcool:
#92 Avtovaz
Avtovaz
  • 1,314 posts
Posted 14 June 2026 - 03:11 PM
you will rememebr this then, Roger Clarkes car
v04-RogerClarke6r4.jpg?t=1781449833
#93 Avtovaz
Avtovaz
  • 1,314 posts
Posted 05 July 2026 - 05:47 PM
not massiev update but still... did a repair to the post
1000012253.jpg?t=1783273488
1000012255.jpg?t=1783273488
did some seam welding to the inner wings and chassie legs, put a plate to cover the holes where the old servo was etc
1000012254.jpg?t=1783273488
My friend howie has bought a pipe bender, so we are looking at making a cage for it now. Lost of work to do stilL!
#94 Avtovaz
Avtovaz
  • 1,314 posts
Posted 18 July 2026 - 09:57 PM
one part of the lada that seem to fail ive been told is the link bars to body. So i looked at them today
1000012480.jpg?t=1784411289
1000012481.jpg?t=1784411289
1000012483.jpg?t=1784411289
1000012484.jpg?t=1784411289
they are 1.5mm plates, will do new bolts instead of studs for the mounts.
one also very bad part of the lada is the handbrake mounts, its on pedastels that are so vunerable, so they are cut off and will get welded inside of the car
1000012485.jpg?t=1784411289
i also did some strengthening of the 5th link mount to body
1000012486.jpg?t=1784411289
1000012487.jpg?t=1784411289
1000012488.jpg?t=1784411289
1000012489.jpg?t=1784411289
i drilled out the spot welds that hold the strengthener for the bonnet latch, reason is i need to put a RHD wiper motor on this car, but no lada factory set up will fit.
1000012490.jpg?t=1784411289
1000012491.jpg?t=1784411289
1000012492.jpg?t=1784411289
so ill be lookign for something like a corsa wiper set up.
at the garage today was this car too, went out in the wrong side of it and for a 2000cc vauxhall it went very well!
1000012506.jpg?t=1784411289
cant wait to get my lada out and done now lol
#95 stuart bowes
stuart bowes
  • 2,615 posts
Posted 20 July 2026 - 08:54 AM
 vauxhall ?
#96 Avtovaz
Avtovaz
  • 1,314 posts
Posted 20 July 2026 - 06:40 PM
 vauxhall ?
yes c20xe vauxhall engine, its got a 60g quaife, and an atlas axel on it.
#97 stuart bowes
stuart bowes
  • 2,615 posts
Posted 21 July 2026 - 08:27 AM
sacrilege !! putting a redtop in a mk2 ..
I was confused, thinking obviously thats an escort right,  im not going mad am I   :lol:
no, fair play to him,  bet that goes like stink.  they sound great too
Edited by stuart bowes, 21 July 2026 - 08:30 AM.
#98 Avtovaz
Avtovaz
  • 1,314 posts
Posted 21 July 2026 - 04:20 PM
yes they are one of the best engines ever. Shame they are so expencive now. Back when they where £150 from a scrapper, i put one into my Lada!
CLICK HERE VID
was good, but the car fell apart.
#99 Avtovaz
Avtovaz
  • 1,314 posts
Posted 30 August 2026 - 08:00 PM
My mate Howie has been away so ive not been to the car for some weeks now. He is back and we will be on it next week i think. I have done some bits else where though!
I bought a bmw m44 engine from Jason HRD racing, it was running but had been sat for a while. it was £200 so i took a gamble.
1000012542.jpg?t=1788119195
1000012553.jpg?t=1788119195
1000012554.jpg?t=1788119195
1000012555.jpg?t=1788119195
cams looked  abit minty but it had been stood for a while. when i stripped it there was signes of water int eh bore, but it all looked good. I took teh block and head to lane ends engeneering prescot, and they did their magic.
It got a new set of rings, a hone, head skimmed, exhaust gasket area skimmed, all valves out and reseated, all very cheaply! Highly recomend them
1000013004.jpg?t=1788119195
1000013061.jpg?t=1788119195
i had teh box at work too, i started to make a box mounted further forward gear stick for it. Reason is box mounted always feels better to me, and also, in teh lada itll work better, its like 4" further forward.
1000013270.jpg?t=1788119195
1000013271.jpg?t=1788119195
not finished that yet as i started on my mk1 golf brake conversion f or the front. I mocked it all up using Lada 2110 discs, they had the wrong offset for me, so i bought some fiat croma turbo discs and it seems like it was meant to be!
1000012858.jpg?t=1788119195
1000012857.jpg?t=1788119195
1000013267.jpg?t=1788119195
1000013268.jpg?t=1788119195
1000013269.jpg?t=1788119195
not quite finished, need to weld some nuts on the bracket to hold the caliper, and then itll get a abs ring and sensor, but i wont be able to do that i think...
these are some special -30mm stearing arms for it, these are for the toyota yaris rack conversion we will be doing soon
1000012798.jpg?t=1788119195
stripped and painted the bootlid, its rough as im using it to mould off, ill be making fiber bonet, boot, floor trays, and a few other bits too
1000012761.jpg?t=1788119195
1000012762.jpg?t=1788119195
1000012763.jpg?t=1788119195
1000012764.jpg?t=1788119195
1000012765.jpg?t=1788119195
My white car is on the road now, its been good, another lad in my town has a green one, and we took some pics of them. really enjoy the cars, cant wait to get thte 2103 ont eh road
1000013028.jpg?t=1788119195
1000013030.jpg?t=1788119195
#100 Avtovaz
Avtovaz
  • 1,314 posts
Posted 13 September 2026 - 08:23 PM
not major progress, infact some steps backward!
First the gearbox stick mount is done, it looks heavy but its strong and will work fine
1000013270.jpg?t=1789330683
1000013271.jpg?t=1789330683
1000013460.jpg?t=1789330683
1000013461.jpg?t=1789330683
well happy with that, and put that into storage for now
Bought a sump for it too and measured up to see if it fits.
1000013488.jpg?t=1789330683
Loads of room, also measured up for the escort type ally fuel tank. my mate had one for the escort so i tried it
1000013489.jpg?t=1789330683
Not quire right, the rear of it hits the spring mounts, so a simple fix could be sorted. but there is a guy very local to howie who makes fuel tanks, sil ill get him to make one and put a sender in it too.
Had a well pleasing time with an air chisel too
1000013490.jpg?t=1789330683
THat sound deadening is well heavy. sorted that out in 1 hour, everyone was deaf afterwards in the garage!
my friend who lives local who i go racing with also bought this, thought id share it here. its a spaceframed mini shell with a hyabusa engine, its 240 bhp. we did some testing at 3 sisters, it is out ofthis world!
1000013523.jpg?t=1789330683
the lada is goign to get an english axel now, its from a mk1 cortina, blackline shafts with the standard bearings, withthe flange on the end. but that means the rear is ford, the front is Lada. So after all the research of the frotn end,, thats gettign changed now, i have bought some cortina front hubs, the lada bearings aparently fit so chat gtp says, and i have heard of it done once before. So will have to make some new caliper mounts. the golf calipers, had a look at them ,  one is totally done in. so for the price of new calipers, plus a little more, i can have 2 ally princess 4 pot calipers. so looking at doing that.
Edited by Avtovaz, 13 September 2026 - 08:27 PM.
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
