Distributor Machine
170 replies to this topic
#91 68+86auto
68+86auto
  • 1,446 posts
Posted 31 August 2025 - 11:01 PM
Looking good.
I was worried that you weren't going to finish it when I read your Facebook post.
#92 gaspen
gaspen
  • 1,192 posts
Posted 01 September 2025 - 05:31 AM
Looking good.
Where I'm lookig for a machine for sale ?  I was wondering how much could be a used one. The I've got an offer for 1500EUR.... reminds me why I started to build one  :D
#93 gaspen
gaspen
  • 1,192 posts
Posted 05 September 2025 - 09:04 AM
Well I don't trust the stiffness of this housing, so I've made a frame instead  :D
And I'm thinking of making another driving hub for the dizzy as this chuck won't hold it securely
Attached File  20250904_135640.jpg   87.71K   0 downloadsAttached File  20250904_130220.jpg   86.86K   0 downloads
#94 gaspen
gaspen
  • 1,192 posts
#95 68+86auto
68+86auto
  • 1,446 posts
Posted 05 September 2025 - 12:41 PM
 I have problems with the chuck on my proper machine when doing Lucas distributors.
#96 gaspen
gaspen
  • 1,192 posts
Posted 07 September 2025 - 06:45 PM
So today I've made a Lucas driving hub, I hope it will be stabile
Next I have to figure out the support for the dizzy. I really like what I can see on old Bosch machines : iz looks pretty reliable
Attached File  20250907_141543.jpg   69.03K   0 downloadsAttached File  20250907_141604.jpg   51.27K   1 downloadsAttached File  20250907_141911.jpg   84.4K   3 downloads
Attached File  1740083717998.jpg   47.87K   3 downloads
#97 Spider
  • 15,811 posts
Posted 08 September 2025 - 06:39 PM
I found that too (though my own machine doesn't have a chuck). You might be better off making a Drive Dog for fitting in the Chuck to drive the Lucas units.
#98 gaspen
gaspen
  • 1,192 posts
Posted 21 September 2025 - 03:35 PM
Good news : it's working  :proud:
Bad news : I can't see it  :D
First thought was that the opening for the light is too narrow, but it's more like because I placed the LED on its side therefore it is not strong enough to see it
I think I should paint the disc to matt black for more contrast.
And I've eplaced the driving hub for a felxible CNC coupling.
https://photos.app.g...FrjJGGePPizAdDA
Attached File  20250921_164505.jpg   101.88K   1 downloads
Attached File  20250921_164515.jpg   56.36K   0 downloadsAttached File  20250921_170501 (1).jpg   41.56K   1 downloads
Attached File  20250916_112938.jpg   39.92K   0 downloads
#99 gaspen
gaspen
  • 1,192 posts
Posted 23 September 2025 - 04:07 PM
Today I've made the support arm for the dizzy. It is pretty stable.
The slip ring became the weak point of the machine. Originally I choosed a small one which fits tightly to the 8mm shaft but its thin and solid wires  can brake easily
Next I will install a bigger one for which I can solder thicker wires.
The test shows that there is something wrong my 25D dizzy : it's rattle as it rotates but I don't know the reason
I also fixed a 45D and it works more silently.
To be continued....
Edited by gaspen, 23 September 2025 - 08:42 PM.
#100 68+86auto
68+86auto
  • 1,446 posts
Posted 24 September 2025 - 05:07 AM
That is usually worn holes in the advance weights and or the spring is loose (fix the holes first). The distributor will usually rattle if shaken.
When they get really bad they wear into the housing at full advance.
Edited by 68+86auto, 24 September 2025 - 05:31 AM.
#101 gaspen
gaspen
  • 1,192 posts
Posted 24 September 2025 - 05:45 AM
I've removed the base plate and turned the dizzy on different rpm's but I can not see the weights moving. It should visible?
How can I fix the holes ?
One spring should be loose, isn't it ?
On the 45D there are different weights, I see as they "fly"  out or in.
Edited by gaspen, 24 September 2025 - 06:06 AM.
#102 68+86auto
68+86auto
  • 1,446 posts
Posted 25 September 2025 - 12:59 AM
Yes you should be able to see the weights come out but they will be a blur due to the speed. Manually play with the weights and advance to see what is happening. See if the weights are loose by moving them with your finger, there shouldn't be much movement. They work the same as the 45D but are just a bit different shape.
For steel weights I find good ones.
In most cases one spring should be loose but there is at least one mini distributor specification which has two identical springs.
#103 gaspen
gaspen
  • 1,192 posts
Posted 27 September 2025 - 11:17 AM
I still have some issues, any advice would be helpful
I've connected my multimeter to check the accuracy of the machine. As you can see it shows 56 degrees but the arc length is far from that value
The given dwell in the specification is for crank or cam degrees ?
For the light I bought cheap chinese LED's but all of them killed  :D  It is possible that these LED's can not resists for the many on-off switching ?
Another issue that the arc lenght stretches with RPM
Here is two short video
https://photos.app.g...Y74B6FRR7ocT9q6
https://photos.app.g...kqKky6ma7YwJsW6
#104 gaspen
gaspen
  • 1,192 posts
Posted 27 September 2025 - 11:19 AM
#105 gaspen
gaspen
  • 1,192 posts
Posted 27 September 2025 - 11:21 AM
