Cam Options
33 replies to this topic
#16 DeadSquare
DeadSquare
  • 3,375 posts
Posted 24 February 2025 - 03:19 PM
Austin, aka BMC, were so besotted about the torque / gallon ratio of the A series, that they were loth to fit anything other than their "All talk, no go" cams, which, although they had stood them in good stead in the post war horsepower taxation system and the mid 50s Suez oil crisis, were dier by the millennium.
Simply fitting the part number 948 cam from the 997 Cooper in a bog standard 848 Mini, made it go the way you felt a Mini ought to go.  It did use more fuel, but you got there quicker.
#17 miniGTS
miniGTS
  • 306 posts
Posted 31 July 2025 - 07:04 PM
I had a chat with the engine builder about some options. He suggested a 731 cam but I've seen some comments that 731 isn't great. I'm thinking to keep the standard GTS cam. I don't know spec of the GTS cam but someone said it's similar to the MG metro cam. Anyone have any experience with a 731 cam in 1275 Or will the GTS cam, assuming it is similar to the MG metro cam, be a smoother cam with enough torque and fun driveability.
He also asked if I want some head porting done, would that be a worthwhile thing to do?
I want something that has power from low down and doesn't need to rev up to 2000 rpm before it shows sign of life. So stick with gts cam or get the 731?
#18 Cooperman
  • 23,510 posts
Posted 31 July 2025 - 09:42 PM
The 731 is an old BMC rally cam. It was not well liked generally.
The MG Metro cam, which is very close to the Kent 266, is excellent, but the Mini Spares Evolution cam is great.
You can get very confused by the huge choice available, but in the end you may not notice the difference in normal road use, After all, you will not be using max revs and full throttle very often.
Of course, cam choice is important when you are looking to save a second or so per lap, but on the road it is different.
The big question is where do you want the torque and the max power. Look at the cam graphs if you can.
#19 whistler
whistler
  • 1,870 posts
Posted 01 August 2025 - 10:19 AM
For a road going engine the EVO001 cam from Minispares is excellent. I put one in my wife's 1330. The other cam that is recommended by some well known engine builders is the Piper 255. I have one in my 1220 (overbored 1098) and gives very good torque.
#20 stuart bowes
stuart bowes
  • 2,528 posts
Posted 01 August 2025 - 10:33 AM
is that still on the standard 1098 crank, and presumably the same block as the 998 (already stroked as 1098, and then bored out)
just asking because I have a 998 A+ and still debating what to do with it.  I like the idea of torque and not overly worried about revs.  I already have a 1098 crank on standby
and stupid question maybe, but re: the EVO cam, is that universal, as in can you use that in 998 as well as the bigger blocks.  or do you have to specify when ordering
(I may still just put it back together as a 998 and leave it to be honest, depends on budget when I get to it!)
Edited by stuart bowes, 01 August 2025 - 10:38 AM.
#21 Cooperman
  • 23,510 posts
Posted 01 August 2025 - 05:01 PM
I put an Evo 001 cam in a 998 Cooper and it was superb. I also just put one in a 1293 MG Midget with a moderately d=ga-flowed head, a decent exhaust system and 10.0:1 CR running on twin HS2's. It's just very smooth and gives excellent torque all the way up the rev range with peak power coming at c.5600 rpm. It's possibly the best road cam out there.
What pistons are you using in the 1220 cc bored out 1098? Is the crank standard throw diameter or offset ground?
#22 miniGTS
miniGTS
  • 306 posts
Posted 01 August 2025 - 06:22 PM
I have a cam that was a regrind and been marked as a 268. After some reading another cam I may consider is a 266 but will chat with the engine builder and see what else he suggests.
I should add that, even though the evo1 cam is a cost effective option in UK, in South Africa it's a special order item and together with an oil pump for it, ends up costing about 20 to 25% the cost of a complete engine and gearbox rebuild.
I'm waiting to hear if the gts cam that came out of the engine is still good to use or needs replacing.
Edited by miniGTS, 02 August 2025 - 07:13 AM.
#23 whistler
whistler
  • 1,870 posts
Posted 02 August 2025 - 08:46 AM
Yes, standard crank but revs limited to 6000 max. I followed a template on Keith Calver's website for this build.
#24 miniGTS
miniGTS
  • 306 posts
Posted 04 August 2025 - 05:20 PM
I think I've pretty much decided to bite the bullet and get the Evo1 cam. Seems to be what I want, low down torque with good pull through the rev range.
I'll skip the cost of nitriding the crank as the gts was tuftrided and currently still on standard, needing to go to 10thou. Besides, I don't think nitriding is really necessary.
Then I may also not do head porting to keep costs down. I'd rather get balancing done and the right cam with the initial build. Head work can be done at a later stage... Maybe.
#25 whistler
whistler
  • 1,870 posts
Posted 04 August 2025 - 06:02 PM
Minispares also have a distributor to match the EVO01 cam for not a lot of money.
#26 Midas Mk1
Midas Mk1
  • 5,822 posts
  • Local Club: S.U.N.M.C
Posted 04 August 2025 - 06:03 PM
I’d go sw5 than evo1, why buy the copy?
#27 miniGTS
miniGTS
  • 306 posts
Posted 04 August 2025 - 06:12 PM
Cost... I'm in South Africa and Evo1 is already expensive here. Sw5 is 3 times the cost
#28 miniGTS
miniGTS
  • 306 posts
Posted 04 August 2025 - 06:16 PM
So I also need a different distributor?
#29 Midas Mk1
Midas Mk1
  • 5,822 posts
Posted 04 August 2025 - 06:37 PM
If you’re fine with a copy? you asked our opinion. Having used both at work, i’d choose the sw5.
#30 miniGTS
miniGTS
  • 306 posts
Posted 04 August 2025 - 06:45 PM
And I appreciate the feedback. I wasn't aware that it was a copy. Because of the cost and so may saying the Evo1 is really good plus of course cost and affordability, I'll settle for a copy. Especially considering my other options are a 731 or 276 regrind...
