You won't be disappointed with the Evo 001 cam. The price - performance is excellent and in the 1293 Midget engine which I have just built it's running beautifully.
Owners and builders can go on and on about different cams, but the vast majority of time the car is not being driven to the limit of the engine power and what is important is the area under the torque graph. If you have a well-flowed head, a decent compression ratio and nice induction and exhaust systems, combined with good carburation, whichever cam you choose from the range of improved road cams will be good. I honestly doubt that if you got into a car with the parts mentioned optimised, you would not be able to tell the difference between an MG-Metro, Kent 266, SW5, MS Evo 001, Piper 270, etc. You might notice the difference on a timed lap of a racetrack but not on the road. Most modern mid-range cams are very good.
My 1990 Cooper historic rally car has an MG Metro cam with standard gear ratios and a 3.44:1 FDR. It has 83 bhp at 5900 rpm and peak torque of 83 ft. lbs at 3800 rpm. On the road I rarely go much over 5000 rpm so I am using most of the torque, but not much of the bhp when accelerating firmly in normal road driving.
I would add that those figures are with a 10.2:1 CR and 35.6 mm inlet valves.
