Posted 29 April 2025 - 09:25 PM
Has anybody done this and have some more info
Thanks in advance
Posted 30 April 2025 - 12:25 AM
Posted 30 April 2025 - 06:54 AM
I did it by modifying the wires going into the back of the switch as follows:
https://www.theminif...need/?p=3765405
Other solutions are possible. Also make sure that the bottom section of the new MC goes to the rear brakes and the top to the fronts. It won't affect ultimate braking performance but will give you a much more natural feeling pedal (mine was wrong for years after an ignorant garage blah blah long story).
Posted 30 April 2025 - 11:17 AM
ignorant main dealer changed mine years ago and locks up the rears.
Posted 30 April 2025 - 09:43 PM
Is this the Master Cylinder it was fitted with ?
https://www.minispar...quare-reservoir
No not that one
Posted 01 May 2025 - 06:01 AM
No not that one
Can you post a photo of what you have ?
Posted 01 May 2025 - 11:15 AM
The pressure failure sensors had continuity across both terminals* so pressing the brake warning switch showed the wiring was good.
The fluid level float just makes the circuit if the float drops, hence the "dibber" sticking up through the lid that makes a better test than pressing the brake warning switch, that just tests the bulb when there's a float switch.
Join both wires at the master cylinder together & also connect them to one side of the float switch. Earth the other side.
* if there was a pressure failure the switch earthed itself via the master cylinder, lighting the bulb. The warning switch, also connected to earth when pressed.
Posted 01 May 2025 - 09:42 PM
That’s fantastic cheers mate
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Rear Opening & Closing Windows For A 1983 MiniStarted by Peter_NottinghamS , 05 Jul 2025 ![]() |
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
