Cooper S 1275 Block And Liners To Downsize
21 replies to this topic
#16 mk3man
mk3man
  • 29 posts
Posted 22 May 2025 - 07:28 AM
Main caps boring from MED was 500 when I asked. Paid 1000 in Germany.
  Guessing that's without the caps?
#17 mk3man
mk3man
  • 29 posts
Posted 22 May 2025 - 07:33 AM
I just paid 240 for steel caps line boring.
  That's not to bad but for me to include everything that needs buying (block, caps, sleaves, stud and nut set) and the all the machining it will end up being very spenny just to get the block usable.
#18 mk3man
mk3man
  • 29 posts
Posted 22 May 2025 - 07:35 AM
If it needs sleeves and main caps, then there’s a lot of parts and machining needed to get it to a useable block.
Then there’s all the other machining and checking needed of threads, corrosion etc. Hopefully it hasn’t had a big skim off the top deck as well
The brand new block from Minispares starts to look like a reasonable option
  Yes totally agree with you, by the time I'd finished, it possible wouldn't be far off the 4k MS want for a new block
#19 timmy850
timmy850
  • 3,382 posts
  • Local Club: MITG
Posted 22 May 2025 - 08:10 AM
@AC.................Ok that's good to know AC, would that not weaken the block? thought the very maximum was 74.7mm? That's ok as I'm in no rush anyway as my shell is still a rot box and unregistered, what would be a rough cost to sleave it? can you line bore the new caps too? also thinking of a 4 bolt center main cap while I'm at it, can you drill and tap that? final question where are you based?
If AC can't help, speak to SMMC, based just outside Royal Leamington Spa.  The sorted out my S block.
Ok cool, what is SMMC?
Southam Mini & Metro Centre
#20 mk3man
mk3man
  • 29 posts
Posted 22 May 2025 - 08:59 AM
Thanks Timmy
#21 Gaz66
Gaz66
  • 960 posts
Posted 22 May 2025 - 11:28 AM
It's surprising how many S blocks come up for sale without caps.
Hmmm, strange 🤔
#22 floormanager
floormanager
  • 710 posts
  • Local Club: Mini Club Sussex
Posted 22 May 2025 - 06:32 PM
<script type='text/javascript' src='https://www.theminif...YIm-yNWnG-4yg=='></script>
Thanks Timmy
SMMC build a lot of engines.  Mine took a year for them to fit in although I was not in a hurry.
