sorry, this is an open forum, others are interested too
Classic Mini Spi Idles Fluctuate
#16
Posted 18 June 2025 - 03:59 AM
#17
Posted 18 June 2025 - 03:06 PM
I get below error when attaching the log file here, hence why I uploaded to google drive.
Error You aren't permitted to upload this kind of file
Also i didn't notice when i upload to google drive, it was under only me view which I have open it to public view now.
Edited by mnr47, 18 June 2025 - 03:08 PM.
#18
Posted 18 June 2025 - 03:10 PM
with "More Reply Options" you may post the logfile here.
Google Drive: "You need access", meaning that the file is not publicly accessible.
#19
Posted 18 June 2025 - 03:29 PM
Yes, I can confirm: now the file is open for viewing.
#20
Posted 18 June 2025 - 04:14 PM
Very serious fault.First thing i guess you have a 82 degree thermostat in it.Water reaches only 85 therefore no closed loop,but this could be the only 5 minutes runingtime. Test that wiith10 minutes.
The more misty fault is that iac drops normal down but at 16:59 it rises up the first time and at17:10 it rises up much more starting with fluctuating running at16:59. I would check the IAC on cold solderings, there is a thread on the beginning here in the forum.
PS.I suggest using mems rosco like the suggestion for BritOP94 or open the file in excel and make a graph from iac and rpm column.
I have no other idea for this behaviour possible others could see more!
#21
Posted 20 June 2025 - 08:01 AM
I am using 76c thermostat and I can confirm the system goes into close loop.
I manage to solve the Intake Temp sensor fault which was caused by the socket/wire faulty. As per below latest screenshot.
WhatsApp Image 2025-06-20 at 3.59.18 PM.jpeg 36.98K
0 downloads
WhatsApp Image 2025-06-19 at 9.11.20 PM.jpeg 26.93K
0 downloads
WhatsApp Image 2025-06-19 at 9.11.19 PM.jpeg 18.92K
0 downloads
Attaching the latest log file as well.
https://drive.google...iew?usp=sharing
#22
Posted 20 June 2025 - 09:13 AM
First of all, you need not quote every answer.
Intake air temperature ist the smallest parameter for a good running engine.In any case good that you found that!
The fault is still at the IAC side.Visualize your logfile in a graph and you will see yourself!
