Rear Opening & Closing Windows For A 1983 Mini
Posted 05 July 2025 - 12:33 PM
Is it possible to all the hinged rear windows?
How easier/difficult a job is it?
I used the search facility to return no matches so I'm surprised that this hasn't been asked before.
Thanks in advance.
Peter
Posted 05 July 2025 - 12:55 PM
it has been asked loads of times, it's just the search is next to useless
you have to use google instead like this (see what I did for the search term)
https://www.google.c...chrome&ie=UTF-8
Edited by stuart bowes, 05 July 2025 - 12:55 PM.
Posted 05 July 2025 - 05:11 PM
Remove old window and seal - easiest option here is to run a Stanley blade around the outer seal then you can pop out the glass, and remove the remainder of the seal.
New opening type seal put in place, then offer in new window, hinge slides over the pinch weld part of the seal - silicone spray helps ease it on.
Some masking tape to allow to mark location for hole.
On C post, mask up C-post trim, roughly where hinge will need to be, again just for easy marking.
Have someone to push the window fully closed, ensuring the gaps look even. Mark the holes for the locking mechanism.
Remove window and seal, drill your holes for the fixing screws, just be careful not to drill too far on the C post that it marks the outer panel.
Rust inhibitor or zinc spray on a cotton buds is the easiest way to protect the holes.
Then it's just a matter of putting the seal back in, offering up the window and screwing it in place.
Posted 06 July 2025 - 11:31 AM
As a point of interest does anyone know what year the opening rear windows were discontinued?
Posted 07 July 2025 - 07:22 AM
Thanks to everyone for their help and input.
I've been away for the weekend and having the occasional peek at the app which doesn't make replying easy.
Peter
Posted 07 July 2025 - 09:12 AM
I'm thinking I could be interested in a swap, if it's of any interest
my two opening rear windows which I think still have hinges and catches attached (but are old and not pristine) for two windows of the right size to be fixed in normally
I'm up in leeds for two weeks 14th to 25th july could maybe pop in on the way there or way back (13th am or 25th pm), I'll be going up and down the M1 anyway
(subject to finding them in shed and them not being damaged or anything)
Edited by stuart bowes, 07 July 2025 - 09:43 AM.
Posted 07 July 2025 - 11:26 AM
Hi Stuart
You have my attention.
This is my Mini:
I'll drop you a DM and we can talk offline.
Thank you.
Peter
Posted 07 July 2025 - 11:28 AM
Other way round I think. MPIs had opening windows up to the end. Not sure exactly when the fixed windows will have stopped but it'll be with the end of a base model like the City. 1992?
Posted 07 July 2025 - 11:37 AM
my main reason for wanting shot of them is I don't want the kids mucking about with them in the back, and the catches are a bit sharp/thin metal , we're driving along and one of them gets their finger stuck and is now bleeding all over my seats.. eugh
I also have a sunroof anyway so added ventilation (that's also painful if you get your finger caught, ask me how I know, but at least it's up front)
also I think I just prefer the 'cleaner' look
but each to their own obviously, I can see the benefits of them as well
Edited by stuart bowes, 07 July 2025 - 11:38 AM.
Posted 08 July 2025 - 08:44 PM
My ‘98 JDM had fixed rear quarter lights, I believe all the export models that had air con had the opening windows deleted.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Converting To Yellow Tag Brake Master CylinderStarted by Nickj270386 , 29 Apr 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
