Would it be these? The blurb isn't clear but does mention M1144. Mine are 8.4s
https://www.minispar...tex-m1802-mlb37
It looks like they are M1144 and that is the marking on the backing plates of the pads in the picture.
I never know why they are given the 'not for road use' tag, as they meet or exceed the requirements for brake pads, contain no asbestos. but cover a broader temperature range than standard pads.
I always thought that the only reason pads might be marked as not suitable for road use is because if they did not fade before the brake disc temps were very high, the brake fluid might boil, which would effectively cause brake failure. I was once using the old Ferodo DS11 race pads and boiled the DOT 4 brake fluid. I changed to AP600 fluid, which replaced the old 'Girling Amber' competition fluid.
M1144 will fade well before DOT 4 will boil, although with M1166 or the C-M pads an AP600 fluid is needed.
For more advice you could call 'Questmead Ltd' in Rochdale who are friction material specialists and can supply what you need for any particular application. They do have a web site.
