Geu930Ms
Best Answer ACDodd , 15 December 2025 - 02:02 PM
As you have now identified it's I variable dwell and powerspark, I can confirm it will run perfectly with a 1.5 ohm coil, no lower.
Ac Go to the full post
32 replies to this topic
#1 gaspen
gaspen
  • 1,192 posts
Posted 15 December 2025 - 08:56 AM
Hello
I bought a GEU930MS distributor from MiniSpares for my 850 but I am confused with the coil.
MS suggests to use a 3 ohm coil for it. Even written on its box to use it with MSC105.
In the other hand I read on this forum and on another sources too that unit with variable dwell I should use 1.5 ohm coils.
My actual dizzy has a white dot on it but I am not sure that it means "low energy" . I guess this type of module does not have a "high energy" variant, sure?
What is your advice ?
Attached File  20251211_130645.jpg   30.05K   1 downloads
#2 shera12
shera12
  • 46 posts
Posted 15 December 2025 - 09:55 AM
Hi, I’d go with what MiniSpares recommends, using the 3 ohm coil with the GEU930MS. The white dot usually just indicates the module type, not high or low energy. Using a 1.5 ohm coil could overload the module if it’s not designed for it. If you want extra reassurance, maybe check MiniSpares or the module datasheet to confirm compatibility.
#3 Ethel
  • 26,713 posts
Posted 15 December 2025 - 10:13 AM
If you have a 3 ohm coil I'd certainly try that first. Worst case, you'll get weak sparks.
#4 68+86auto
68+86auto
  • 1,426 posts
Posted 15 December 2025 - 11:03 AM
That looks like one I'd use a 3 ohm coil with. The dwell is most likely fixed on that one.
#5 Lplus
Lplus
  • 1,000 posts
Posted 15 December 2025 - 12:45 PM
If you do what Minispares say and it fails they can't complain you didn't follow fitting instructions.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 15 December 2025 - 01:07 PM
Follow the suppliers instructions. Fixed dwell needs a 3ohm coil. A variable dwell unit will run much better with a 1.5ohm coil, but ONLY if rated for it.
Running a 3 ohm coil on variable dwell reduces the spark power at lower rpm, and therefore you actually have less power than running points!
It's the basics of this that people need to underStand if they give advice on forums.
You would have been better off to fit one of these along with a 0.8 ohm coil, 3 ohm coils have no place in any a-series nowadays,
https://www.minispar...-276-cam-profil
Ac
Edited by ACDodd, 15 December 2025 - 01:18 PM.
#7 gaspen
gaspen
  • 1,192 posts
Posted 15 December 2025 - 01:45 PM
I totally understand this. But : this actual dizzy equipped with a PowerSpark module, see the picture
In PowerSpark's catalog I can't find only one module for 25D for -ve earth.  This one Powerspark Electronic Ignition Kit for Lucas 25D & DM2
Are these units the same or not ?
Additionally I've tested this dizzy on my distributor machine and it has variable dwell.
I accept if I have to use a 3 ohm coil but I'm confused at the moment  O_O
I will be use this car with a C40 dynamo, capable of 22A load. The 0.8 ohm coil will charge it ~17A, sure ?
Attached File  20251215_115256.jpg   43.55K   1 downloads
Edited by gaspen, 15 December 2025 - 01:51 PM.
#8 gaspen
gaspen
  • 1,192 posts
Posted 15 December 2025 - 01:49 PM
Where can I find a datasheet of this module ?
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 15 December 2025 - 02:02 PM   Best Answer
Ac
#10 gaspen
gaspen
  • 1,192 posts
Posted 15 December 2025 - 02:08 PM
Ac
Thank you very much AC and sorry that I did not write in the first post  :shy:
#11 gaspen
gaspen
  • 1,192 posts
Posted 07 January 2026 - 07:56 AM
One more question : where would you set the static or strobe timing for this dizzy ? My guess is static TDC / 3-4 degrees at 1000 maximum
Unfortunately MS won't share this information nor the theoretical curve.
My test shows on the black graph (blue and orange is 41026 factory data)
Attached File  Képernyőkép 2026-01-07 085429.jpg   21.89K   0 downloads
Edited by gaspen, 07 January 2026 - 07:57 AM.
#12 Lplus
Lplus
  • 1,000 posts
Posted 07 January 2026 - 08:38 AM
Seems reasonable to provide the same level of advance at high revs, since the static timing of the 41026 was tdc.
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 07 January 2026 - 09:02 AM
Is your graph showing dizzy advance or crankshaft advance?
Timing is set at full advance figure, if your engine needs 28degrees to achieve max power, then time it at 28degrees at 5000rpm. The lost motion in the engine and the advance curve shape will determine where the static advance ends up.
Basically you don't time an engine at idle.
Ac
#14 shera12
shera12
  • 46 posts
Posted 07 January 2026 - 09:40 AM
Stick with the 3 ohm coil MiniSpares recommends the GEU930MS is designed for it. The white dot isn’t “low energy,” and there’s no high-energy version, so you should be fine.
#15 gaspen
gaspen
  • 1,192 posts
Posted 07 January 2026 - 09:55 AM
These are crank values. I measured it on my distributor machine and mutiplied by 2 for the graph. The engine is restored but remained a standard 850, the car is still in the paintshop but I would like to prepare myself
I know this but I will need a basic setup for the 1st start.
Theoretically : if the engine is happy with 28 d's max advance, but the dizzy produces 30 d's it should be adjusted to 2 d's static ATDC ?
In practice I should limit the max advance by 2 d's at least ?
