Geu930Ms
Best Answer ACDodd , 15 December 2025 - 02:02 PM
As you have now identified it's I variable dwell and powerspark, I can confirm it will run perfectly with a 1.5 ohm coil, no lower.
Ac Go to the full post
32 replies to this topic
#16 Lplus
Lplus
  • 1,000 posts
Posted 07 January 2026 - 10:27 AM
Is your graph showing dizzy advance or crankshaft advance?
These are crank values. I measured it on my distributor machine and mutiplied by 2 for the graph. The engine is restored but remained a standard 850, the car is still in the paintshop but I would like to prepare myself
Timing is set at full advance figure, if your engine needs 28degrees to achieve max power, then time it at 28degrees at 5000rpm. The lost motion in the engine and the advance curve shape will determine where the static advance ends up.
Basically you don't time an engine at idle.
I know this but I will need a basic setup for the 1st start.
Theoretically : if the engine is happy with 28 d's max advance, but the dizzy produces 30 d's it should be adjusted to 2 d's static ATDC ?
In practice I should limit the max advance by 2 d's at least ?
The static timing for an 850 with the 41026 was tdc.  The max centrifugal advance for a 41026 is 34 crankshaft degrees.  Thus the max centrifugal advance for an 850 is 34 crankshaft degrees,  Give the max advance evident on your new distributor appears to be 30 crankshaft degrees, it would be a good idea to add a small amount of static timing advance, say 3 degrees to ensure your max timing remains within the envelope you show for the works advance curves.
#17 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 07 January 2026 - 12:48 PM
That curve is next to useless, build something with 12 degrees static, 22 degrees at 2000 and 34 degrees full advance at 4000rpm.
Install at 12 degrees BTDC static for first start, time dynamically after it's running.
Ac
#18 Lplus
Lplus
  • 1,000 posts
Posted 07 January 2026 - 01:33 PM
Ac
So given 12 degrees static that would require a curve that produced 10 degrees at 2000 rpm and 22 degrees max from 4000rpm?  Adding the 12 static setting that gives your 22 degrees and 34 degrees.
#19 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 07 January 2026 - 02:11 PM
That is correct.
Ac
#20 gaspen
gaspen
  • 1,192 posts
Posted 07 January 2026 - 03:28 PM
Ac
Thanks a lot AC ! It is very heplful  :proud: I have no chance to send my dizzys to you from Hungary, I wish I could
May I ask some suggestion about my other dizzy as well ?
Bau1962Ms Distributor - Problems, Questions and Technical - The Mini Forum
#21 Lplus
Lplus
  • 1,000 posts
Posted 08 January 2026 - 07:50 AM
That is correct.
Ac
Where would one find a supplier of the correct cam/endstop and springs of the correct strength/length to achieve that advance curve?
#22 gaspen
gaspen
  • 1,192 posts
Posted 08 January 2026 - 07:59 AM
That is correct.
Ac
I guess there is no spare parts available for these units. For less advance* you have to solder/weld to the stop or rasp from it for more advance.
*Is it a usable idea to place a small ring around the spring"s post to achieve less advance ? I see this solution in another type of dizzys.
#23 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 08 January 2026 - 08:03 AM
Watch both parts;
https://youtu.be/3WJ...z0DwaJvCakxYXQM
Adding metal to the stop is how you reduce the total advance length.
Ac
Edited by ACDodd, 08 January 2026 - 08:16 AM.
#24 68+86auto
68+86auto
  • 1,426 posts
Posted 08 January 2026 - 09:18 AM
The washer won't be able to go on without interfering with the spring.
Edited by 68+86auto, 08 January 2026 - 09:19 AM.
#25 gaspen
gaspen
  • 1,192 posts
Posted 08 January 2026 - 10:29 AM
What type of bushing is that ?
Attached File  20251228_173438.jpg   40.28K   1 downloads
#26 gaspen
gaspen
  • 1,192 posts
Posted 11 January 2026 - 07:04 PM
After grouping my springs and some trial I've ended up with this curve. The original primary spring was almost good, but I made it a tiny bit shorter. For the secondary I've found a little bit weaker. Also I weld-up the cam for 11 degrees max. advance.
(I've added 0.5 degree for the red graph to see the "difference")
Attached File  Képkivágás.JPG   69.08K   5 downloads
Edited by gaspen, 11 January 2026 - 07:06 PM.
#27 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 11 January 2026 - 08:10 PM
That should run hard.
Ac
#28 gaspen
gaspen
  • 1,192 posts
Posted 11 January 2026 - 08:16 PM
Ac
What do you mean by that?
#29 ACDodd
ACDodd
  • Mini Docs
  • 2,835 posts
Posted 11 January 2026 - 08:40 PM
Run well/strong.
Ac
#30 gaspen
gaspen
  • 1,192 posts
Posted 11 January 2026 - 09:34 PM
Run well/strong.
Ac
Oh, I see  :D
We will see at springtime...
