Mpi Rad Cooling Fan Stays On
5 replies to this topic
#1 theoldmini
theoldmini
  • 162 posts
Posted 19 July 2026 - 04:33 PM
Need help.  The rad cooling fan on my mpi comes on when in traffic and when outside temp is high.  The problem is it does not go off again until I turn off.  I have changed the sensor near the thermostat and also the wiring to the sensor as Rover tech fix. Where do I go now as dont want fan running when should not.  Temp gauge only gets to half on the gauge.  All help appreciated.
#2 Ethel
  • 26,761 posts
Posted 20 July 2026 - 11:01 AM
I wouldn't know, but it is switched by a relay so you could investigate there.
https://www.theminif...ne-not-yet-hot/
#3 Steve220
Steve220
  • 5,140 posts
  • Local Club: BMC
Posted 20 July 2026 - 01:34 PM
The fan relay is on the firewall near the fuel inertia switch. Worth swapping it for a known good one, could be sticking.
#4 theoldmini
theoldmini
  • 162 posts
Posted 21 July 2026 - 07:19 AM
Thank you.  Will be looking today
#5 theoldmini
theoldmini
  • 162 posts
Posted Today, 02:57 PM
Still have issues.  Have changed the sensor the wiring harness the relay and now the thermostat.  The fan come on today after approx 5 miles  of steady driving.  the temp gauge was just under half. Last resort pull the fuse but dont really want to do that. More suggestions to resolve this please.  Thank you
#6 Quinlan minor
Quinlan minor
  • 1,374 posts
Posted Today, 04:42 PM
Check thoroughly the connections at both ends of the sensor wire and continuity, in the wire? Wiggle the wire while checking.
Any disconnection will trip the cooling fan into a safety mode, ie. remain on.
