Yet Another "bleed The Brakes" Problem
16 replies to this topic
#16 gazza82
gazza82
  • 3,094 posts
  • Local Club: TMF+
Posted 29 August 2026 - 01:26 PM
Before you strip it remove the pipes from the master cylinder, blank off the master cylinder ports to see if you have the same symptoms to try and identify if indeed the fault is with the master cylinder / brake servo.
Newbie question: how do I blank off those two ports? I guess there can be quite some hydraulic pressure on those points.
with two bleed screws
#17 bpirie1000
bpirie1000
  • 2,554 posts
  • Local Club: Amoc
Posted 29 August 2026 - 07:15 PM
I usually use the bleed nipples in where the brake pipes go. Then you can bleed fluid and see which (if any) of the cylinders are to blame..
Good luck..
