Slow Cranking With Clutch Depressed
21 replies to this topic
#16 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 22 September 2026 - 09:15 AM
I'd personally do the wear checks as detailed above and see what they are, then report back, I think you will have issues somewhere
#17 Earwax
Earwax
  • 606 posts
Posted 23 September 2026 - 07:57 PM
Hi Aridgerunner.      As above please consider further. If the clutch being depressed adds a significant enough resistance to overcome a poor battery then at the very least a clutch adjustment is necessary- but it could still be an installation issue. T
#18 Aridgerunner
Aridgerunner
  • 251 posts
  • Local Club: None
Posted 24 September 2026 - 11:50 PM
I went over the clutch adjustment as has been described here many times in the past. The stop bolt clearance is correct. With the clutch fully depressed I ran the overthrow nut up to the case. Then with the clutch pedal released I turned the nut another half flat in and locked the nuts together. I started the engine and could not select any gears. And I could feel that the pedal was no longer hitting the floor. I then began backing off the overthrow nuts a few flats at a time until I could select any gear. I now have a clearance between the case and the nut of about .100"
I look forward to your comments. I think?
#19 Lplus
Lplus
  • 1,004 posts
Posted 27 September 2026 - 04:32 PM
To set the overthrow nuts, slack them off a long way then prise the clutch lever away from the bellhousing as far as it will go and hold it there.  This pushes the clutch onto the end of the crank.  Now screw the stop nuts back to the face of the housing and let the lever return.  Now screw the stop bolts in a further half a turn and lock them.
#20 Spider
  • 15,850 posts
Posted 27 September 2026 - 05:45 PM
Adjusting the Over-throw nuts back beyond having any clearance is doing nothing for any adjustment. If you are unable to get full disengagement with normal adjustments done, then something is worn or there's an issue on the actuation side if the arm (hydraulics, work pins, pedal etc), or the Primary Gear is locking for some reason (bad bushes, insufficient end float, pinching under the flywheel)
While this is not how the factory recommend it be done, it's how I set them too. The whole point of them is to prevent over-loading of the Crank Thrusts.
#21 Cooperman
  • 23,567 posts
Posted Yesterday, 05:11 PM
With the pre-vertical clutch, when the pedal is fully depressed the very top of the clutch arm should have a linear movement of between 0.5” and 0.6”. If it has less than this there is a hydraulic problem which is usually the slave cylinder or the flexible hose.
Back the overthrow nut(s) well off and check this linear movement before doing anything else.
#22 Aridgerunner
Aridgerunner
  • 251 posts
  • Local Club: None
Posted Yesterday, 09:37 PM
Thank you for that information. I have not been able to do any work in the shop for a few days. And it may be a while before I can. When I get the chance I will check that measurement. The hose to the slave cylinder is a new braided one. The master cylinder is the original from 1978, I think. I did put a in a rebuild kit.
Anyway, thanks again.
1 members, 1 guests, 0 anonymous users
    Chris1275gt
