Hi , I'm having an issue with my brakes
4 pot mini sport calipers
Pedal travel stops 2cm off the floor, brakes are operating but with out bite.
It's got newish pads & rotors.
I was reading on Mini sport website that there's a Cooper S specific master cylinder, same bore but taller by 15mm
With increased fluid capacity , so I assume (???) longer stroke meaning more "umph" in the system
Any advice to offer ?Your assumption is incorrect. The volume is only there for pad wear in extreme situations. Like is says increased capacity. The stroke is the same.
so back to the problem. Poor pads? You don’t say. Poor rotors? you don’t say. Poor installation. No images.
But the calipers aren’t the best they do flex.
That's interesting, I was thinking about getting a set of the Minisport 4 pots, can you tell me how you measured the flex, the amount of movement and at what pressure it happened?
Shooter
