The Timken bearing comes with a very thin shim for just this situation , check the packet the bearings came in. I think I did mention this in your " where is the spacer" post.
Shooter
Fitting that shim will make them tighter.
I presumed you can fit the shim between the shoulders giving a bit more clearance as well as behind no?
Shooter
Tight Wheel Bearings
Gaz66
, Today, 01:14 PM
16 replies to this topic
#16
Posted Today, 09:42 PM
#17
Posted Today, 10:12 PM
You appear all over this, so hopefully you can get a work around. Just a thought - are the drums and liners out of play completely.
I haven't got as far as fitting any drums or linings yet but as they are new too I'm hoping they all fit nicely...... I must admit its not looking good up to now though 😁
