Unusual tuning mod
Posted 03 December 2006 - 11:53 AM
The plan is to make an aluminium trailer big enough to carry a mini and tow it with a mini.
The help i need is on the engine, i want to build an engine of very high torque and as cheap as posible.
I know i need a long stroke and a small carb to produce torque, but not sure what valves or head or block to use, large or small valve head. I am thinking it may be just a case of mixing standard mini engine parts together instead of buying modified parts, any help please.
Posted 03 December 2006 - 12:04 PM
Posted 03 December 2006 - 12:11 PM
As said, you WILL be outside the towing regulations.
Posted 03 December 2006 - 12:12 PM
That wont be a problem its a very light mini and an aluminium trailer.You might want to look into the towing regulations first. I believe that you're only allowed to tow a certain weight based on the weight of the tow car. I think it's something like 85% of the weight of the tow car.
Posted 03 December 2006 - 12:16 PM
Re: your engine question....get hold of the David Vizard 'bible' and do some homework! That will tell you most of what you need to know...and more!
Posted 03 December 2006 - 12:27 PM
Thanks ian
Posted 03 December 2006 - 12:55 PM
The only other way I know of increasing torque is to go for twin SUs, and not massive ones either, the smaller throat of the carb increases the air speed through the carb, also sucking more petrol through and thus increasing torque. Obviously there becomes a point where too small a throat won't allow enough air/fuel through.
Posted 03 December 2006 - 01:02 PM
go and look on the MLMotorsport forum and look at the spec of the engine AC Dodd has made for himself. Torque monster.
Posted 03 December 2006 - 01:10 PM
cheers will have a look but trying to keep it cheap 1275,1100,1000 standard parts1380 with a 998 cam and twin 1.25" Carbs.
Posted 03 December 2006 - 01:37 PM
If you're keen on using standard parts that'll really be the extent of torque you'll reach. if you want more pulling power, consider using a 850 or van/pickup diff (3.76:1). It'll be revving its balls off at anything above 75mph, but it'll help with grunt quite a lot!
Posted 03 December 2006 - 01:48 PM
just trying to get round the theory of it all, its been 20yrs since i modded 'a' series engines
Edited by koss, 03 December 2006 - 01:53 PM.
Posted 03 December 2006 - 02:00 PM
Posted 03 December 2006 - 02:01 PM
Posted 03 December 2006 - 02:11 PM
Posted 03 December 2006 - 02:22 PM
for lots of torque i was thinking a 1380 but std head, kent 256 cam and downsizing the carb to a single 1 1/2"!!
with 1380 bore and a long stroke crank you can make 1500cc and with the 256 cam it'll be fine at low revs, LOADS OF GRUNT!!
tow bar fits easier onto a metro by the way!!
